Question about Toshiba Satellite A135 Notebook
Satellite p100 cannot read disks, at all
Does not even recognise there is a disk in the drive, tried reinstalling through troubleshoot recommendations
cheers 4 the help
luke
    Sergeant:
    Champion:
  • 283 Answers
Need to check your optical drive.Its leans might not working.tnx
Posted on Jul 29, 2009
My toshiba Satellite C650 . DVD drive will not recogise any bootable disks. works ok on other disks
If the OS installed is newer than your discs, it is probably trying to protect itself. Windows does this sort of thing.
Jan 20, 2014 | Toshiba Satellite Computers & Internet
Disk drive will not read or play any disk / dvd?
You just might have a corrupted registry but it's easy to fix though just click on start - run - type regedit then In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters and or LowerFilters then delete both of them (sometimes only one of either of this shows up, but that's ok)
After deleting filters restart the computer and that should fix the problem.
Should you have any other questions just kindly leave a comment.
Cheers~
Jul 06, 2010 | Toshiba Satellite Pro L300 Notebook
I want to format my hdd and re install oem. how do i format on p100
Your Laptops comes with recover disks ,Insert the disk,boot the laptop from the recovery disk.It will format your laptop to its original state.
Good Luck
Siju.D
Nov 05, 2009 | Toshiba Satellite P100 Notebook
My internal hard drive is recognised as removable???
Your problem is Vista. It is the pits and by far the worst modern OS, second only to Windows Me. (Millenium Edition).
You need to start at the beginning. Go into DOS, use FDISK to Format the Drive, Go to BIOS and Assign it as the main disk. Disconnect any other HDs if you have them. Reinstall Windows 7 Pro if you can find a copy.
However, did you try this?
http://www.tomshardware.com/answers/id-1983753/hdd-showing-removable-disk-drive.html
hard drive suddenly became recognised as removable disk Google Search
Mar 20, 2017 | Fantom Titanium II (TFD500C16) 500 GB USB...
The dvd is not reading disks you can open it and explorer shows the D drive but there are no files. I have run a driver scan and says driver is ok Toshiba SA 60
Hello my friend, try to clean your DVD Disk drive . You can use Liquid CD Cleaner to ensure the cleaning of your Disk Drive is properly clean. If you don't have a CD/DVD Disk Cleaner kindly check it in the nearest Computer or Video Shop in your place in order to buy and clean your Disk Drive.
Hoe this solution able to help your problem solved. If you need more assistance just reply to this post.
Thank you
geo_jonas
Jul 09, 2009 | Toshiba Satellite A60 Notebook
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
Problem with disk drive A:
First, you should try to keep the floppy drive. If you can find one, I highly recommend getting the floppy drive cleaner diskette. They're hard to find now, but it's worth it if you want to continue to use your floppy drives. If cleaning it doesn't resolve the issue, next item to try is replacement of the floppy drive. You can borrow a floppy drive from someone, plug it in and test to side if it fixes the problem, if not, then it's either a motherboard issue (which I doubt) or a software/windows XP problem (more likely of the two). In which case I would recommend reinstalling windows XP to see if it fixes the problem before shopping for a new motherboard or a new computer.
Good luck
Jun 29, 2008 | Dell Dimension 2350 PC Desktop
RW Combo
check your power supply data cable.
check also your disk.
clean your lense.
if u have warrenty replace it.
Mar 28, 2008 | Computers & Internet
Reinstallation with recovery disk
I've had myself almost same problem in my 5200-801, but with reading DVD's.
It was allready the second dvd/cd drive replaced by Toshiba.
Then I replaced the DVD/CD drive myself because I ran out of guarantee, with one bought from the internet and much cheaper than the original one. A multi drive which even do the lightscribe job and that one works very well.
Nov 13, 2007 | Toshiba Satellite Satellite 5200 Series 15...
Toshiba Satellite A135 Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
