Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bissel Proheat Carpet cleaner
Hi, The water and flud are not being activated by pulling the trigger when it's on floor cleaning, the brushes are turning OK. The water and cleaning fluid work OK via the attachement hose. Help please
  • 2 more comments
  • SK81 Jan 04, 2008
    I have the same problem but water isn't coming out of the attachments either! looked around the heating element and it's fine as machine is not that old? any ideas
  • Dr_Kit Apr 05, 2008
    Everything seemed to work fine put no water was coming out & the flow indicator was not spinning. After taking the heater apart, cleaning it & putting everthing back together everything works great.
  • Anonymous Mar 18, 2014
    Have already cleaned the heating unit, but still no water or shampoo out of the bottom. Water is heating and flowing out via the spin cap when unscrewed. Problem progressed quickly from just no shampoo to no shampoo and water. Is this a clogged hose or a pump failure? If it is the water pump, why does the hose attachment work fine?
  • Anonymous Mar 25, 2014
    The cleaning solution is mixing in the clean water tank
My Bissell had the same problem. The hand attachment does not use heated water. So I Found a clog of calcium and dirt in the heater portion of the unit. The heater is in the handle behind the red heater light on the front. Remove the upper portion of the handle. Remove the lower two screws in the lower portion and the parts will split apart. Remove the hoses and remove the heater. (mark where the wires go) The bottom of the heater can be removed with a screwdriver. The tubes leading into the heater is where the clog was but there was a lot of debris inside Make sure to clear it all and the hoses as well. I put it together and it works great.
Posted on Nov 25, 2007
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
Jan 30, 2014 | Bissell 1699 ProHeat Clear View Upright...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
No water comming onto the cxarpet
remove the water tank and pull up those two red tabs unhook them and push something small thru them they are clogged up that is where your water releases it works I just did it and my bissell works great now!
Feb 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No cleaning fluid or water comming out of cleaner
not sure of your model but on most of the bissell's ( except there new style) the belt drives the pump and the brush on the bottom. no pump action then no spray action. you probably need a new belt.
Sep 03, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Apr 18, 2008 | Bissell Vacuums
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
612 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
