Question about Multitech Systems MultiModem II MT2834BL (354519)
I am using internal modem. i have facing an error 692
My name is raju
  • 1,555 Answers
Hello Mr Raju how can I help you. Since you have talked your problem in the subject it is not visible to me. So kindly comment back here for providing solution.
Posted on Jul 29, 2009
Internet connection error 734 extra initialization command does not work.it leads to another error 692.
692 - Hardware failure in port or attached device.
This behavior can occur if any of the following conditions exists:
  • The modem is turned off or malfunctioning.
  • If you have an external modem, the serial cable is incorrectly wired.
  • If you have an external modem, the serial cable is not securely connected or has open connections.
  • The serial port or multiport adapter on the RAS server or client is malfunctioning.
  • The handshaking options for the modem are incorrectly configured.
  • The modem is unsupported, or the chosen emulation may be incorrect.
  • The modem .inf files become corrupted or the modem driver becomes corrupte
To solve this problem, use the appropriate method:
  • Reset your modem. Consult the documentation for information about how to reset the modem.
  • If you have an external modem, make sure that you are using the correct serial cable. For more information about requirements for proper cabling, refer to the "Cabling Requirements" section in Dial-Up Networking Help.
  • If you have an external modem, make sure that the serial cable is connected securely.
  • If you are using a pin adapter to connect your external modem to your serial port, make sure that the pin adapter is wired properly for modem communication. For example, a 9- to 25-pin adapter for a mouse does not work properly with an RAS serial setup.
  • Test the serial port or multiport adapter, and replace the adapter if necessary.
  • Make sure that the handshaking options for the modem are configured properly. Consult the documentation for information about the different handshaking options that are available for your modem.
  • Contact the modem manufacturer to see if any setup and initialization information is available for your modem. Also, check the latest Windows hardware compatibility list (HCL) to make sure that your modem is supported.
  • Use Device Manager to remove the modem. You can do this in safe mode or in normal mode. Restart the computer in normal mode. Windows will redetect the modem and reinstall the correct drivers.
May 12, 2011 | Computers & Internet
Error 692 held here n m not connect to my new dailup device
Telephone the Internet Service Provider that your modem is trying to connect to, and ask them for Technical Support. If they cannot give you any help, switch to a different I.S.P. that _can_ help you.
May 31, 2010 | Computers & Internet
I have s dell studio 15 laptop. i got a dell conexant rd02-d400 modem so i could use dial up with it. now i get errors that say it can't connect, but that everything os ok.. error 692 and 618 (i think)...
hello,
Connect your modem to the phone line and test the modem.
Control Panel-->>Phones and Modems. Click icon. Tab Modem. Highlight your modem, and Click Properties--->>Diagnostics. Verify that everything is OK.
Then Start --->>All Programs -->>Accessories-->> Comunications ---Hyperterminal.
Enter a name for a bogus connection, Click OK
Enter your phone number and dial it. If Phone/Modem connection is OK, you shoul hear the busy signal.
Alternative:Run the Dell diagnostics.
If Modem connection is correct you must then create a dialup connection.
Hope it helps.
Sep 12, 2009 | Dell Computers & Internet
There is an Error 692 : There is hardware failure in your modem.
Dear!!!
Error : Hardware failure in port or attached device.
Solution :
1. Check to make sure the correct modem is selected in the dialer.
2. Make sure there are not multiple modems installed.
3. Uninstall and reinstall the modem.
4. Make sure that no other programs are using your modem. Fax software, Supervoice, etc...
5. Ctrl-Alt-Delete, if you see RNAAPP loaded,
6. Send to manufacturer?
Dec 14, 2008 | Multitech Systems MultiModem II MT2834BL...
New ADSL Modem on Windows 2000 Generates Error 692
5. Get a new modem, send it back.. Your computer is just fine.
was i helpful enough?
Nov 23, 2008 | Computers & Internet
Modem problems
Try unistalling and reinstalling the modem drivers.
Nov 03, 2008 | HP Compaq dx2000 Microtower PC Desktop
Hardware failure in a modem error-692 in samsung explore
try go to your control panel open phone and modem delete the samsung modem in there and re install it.
Feb 10, 2008 | Cell Phones
Computers & Internet Logo
147 people viewed this question
Top Multitech Systems Computers & Internet Experts
Michael Vincent Cruz
Vladimir Frolov
Larry Fostano
Larry Fostano
Are you a Multitech Systems Computer and Internet Expert? Answer questions, earn points and help others
