Question about Bravetti Food Processors
Food processor model KP80B - I'm just wondering if the motor is frozen in place. I haven't had time to use it since my parents were ill and I had to be over at their place. After they passed on, I came back and tried using it and it wouldn't start. I bought it after watching a TV show. Any help will be much appreciated. Thelma Asato.
  • 19,396 Answers
If it does not start at all, then it is likely one part that had not been mounted properly.
If the blender or the tool used is not mounted in the proper way the processor will not start.
Remove the tool and mount it back in place, possibly following the instructions if you have them.
If still no luck and you are sure the processor is mounted in the right way, then check if the power cord has a built in fuse, and test the unit on a different socket.
When the unit does not start it is usually because of assemblage problems.
Regards.
G.
Posted on Jul 29, 2009
Need replacement bowl/lid for kp80B model euro pro food processor
Call Euro-Pro at this number 877-646-5288. they should be able to help you.
Aug 03, 2012 | Euro-Pro Food Processors
I have the Bravetti Food Processor-Model # KP80B. The unit that uses each individual blade (that is stored in the processor) is cracked and won't work with any of these blades (like for cole slaw, etc.)...
I went to my manuals sites and they did not list this brand.
the internet indicated the problem with this food processor was the inability to obtain parts.
I advise keeping an eye on ebay if you need something in particular.
(if this has been helpful, please give me positive feedback)
Dec 29, 2009 | Bravetti Quad Blade Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Bravetti Food Processor Model KP80B
That's alot of bad outlets.Are you sure there's nothing wrong withe the processor? Just kidding. How long have you had this processor? Any chance of taking it back?
If not, try this. With the unit unpluggedput an attachment on that you can hold onto and try to rotate the motor. Not all are tested and sometimes the motor brushes are not making good contact. If you turn it manually you may get lucky and set them to work. If you get it running, chk with power after several turns, run it constantly for abot 5 minutes to seat the the brushes. Remember to have it unplugged when you have your hand on the attach ment. Good luck. Ned
Aug 24, 2009 | Bravetti Quad Blade Food Processor
I need a manual for Bravetti food processor model KP80B. Is there one I can download? Received as a gift.
Hi!
You can donwload free Owner's Mnaual for Bravetti Food Processor Model KP80B from the following link--
Owner"s Mnaual for Bravetti Food Processor KP 80B
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 27, 2009 | Bravetti Food Processors
Black & Decker F1 CFP 10 food processor bowl cracked
Does anyone want to SELL me their Black & Decker Shortcut Food Process that they cannot get parts for? s.lamos@comcast.net
Jan 25, 2009 | Black & Decker FP1400 Quick N Easy Plus...
Model kp80b
You can see all of the blades and their function in the user manual.
The Bravetti KP80B food processor user manual can be read and saved from this website
http://www.euro-pro.com/europro/manuals/KP80B.pdf
If it's not there let me know and I will send it to you.
Rj
Sep 12, 2008 | Bravetti Quad Blade Food Processor
The cuisinart food processor doesn't work.
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Aug 26, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Bravetti Food Processer
You can get parts from this company.
http://www.euro-pro.com/europro/productdetail.aspx?pid=E50ADA3D-BACA-44E7-9E78-05263C526241(Euro-Pro+Base+Catalog)
You can call them as well
For technical support, please call us toll-free at 1-800-798-7398. Hours are Monday through Saturday from 9:00am to 6:00pm Eastern Standard Time.
Jun 30, 2008 | Bravetti Quad Blade Food Processor
Food Processors Logo
Top Bravetti Food Processors Experts
Greg Cann
Greg Cann
Lawrence Oravetz
Are you a Bravetti Food Processor Expert? Answer questions, earn points and help others
