Home | D-Link | DES-1008D 8-Port Ethernet Switch (79... | How to check whether its...
D-Link DES-1008D 8-Port Ethernet Switch
Problem for D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
How to check whether its working or not working?
By kareem_s on Jul 29, 2009
how to check whether its working or not working?
Best Solution
posted on Jul 29, 2009
Very Helpful)
toac990
Rank: Guru
Rating: 92%, 123 votes
If your PC LAN Card is active just connect the switch with Straight cable - & --you will see one yellow box in ritht side corner down to monitor screen...where the time appears.....also you can check in the Network Connections Folder. Or Right Click My Network Places> Properties> You will see local area Network....> Connected...then it is working if disconnected it's not working....Good Luck
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
Geekman
Rank: Guru  D-Link Computer Networking  Expert
Rating: 85%, 1667 votes
When the computers are powered up and connected to the D-Link hub,
the computers that are connected to the hub will light up the various LEDs on the hub to indicate which port on the hub is active. Also that computer's network card Link LED light should be on to indicate it is connected to the hub.
If the hub's LED is off and the corresponding computer's network card Link LED is off then the network cable is faulty, or the network card is faulty (or the network card driver needs installing) or the port on the hub and/or hub is faulty.
To determine which item is faulty, swap network cables around, swap computers to different ports on the hub etc.
Was this helpful?
Yes
No
Popular Solutions for D-Link DES-1008D 8-Port
Questions and Unsolved Problems for D-Link DES-1008D 8-Port
Do you recommend D-Link DES-1008D 8-Port Ethernet Switch (790069217708)?
Answer
Answer
My net extenders are not working anymore. They were working a day or two ago and now just stopped. I... (More)
Answer
I am resident of 50 Sierra Vista Ave. Will I get Goole Wifi network? if yes then how?
Answer
hi, i need the gateway number for the d-link DES1008D can sombody tell me please how to find out the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For D-Link DES-1008D 8-Port...:
Top Networking Hub and... Experts
Rank: Guru Guru
Solutions: 1347
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Networking Hub and... Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
