Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
HOW TO CONNECT IT TI A COMPUTER?
POWER IS ON BUT WHEN CONNECT TO A SYSTEM, ITS NOT WORKING
  • Mohd. Tareq
    Mohd. Tareq May 11, 2010
    For this type of support you need to write the full issue....how it's behaving etc. etc......now please let me know after connecting with pc the power light is also going off???? or the LAN linked lights are not working....??? Do your pc showing Local Area Connection 10.00mbps connected....?? please clarify & try to write the full issue...
  • D-Link Master
  • 32,281 Answers
When the computers are powered up and connected to the D-Link hub,
the computers that are connected to the hub will light up the various LEDs on the hub to indicate which port on the hub is active. Also that computer's network card Link LED light should be on to indicate it is connected to the hub.
If the hub's LED is off and the corresponding computer's network card Link LED is off then the network cable is faulty, or the network card is faulty (or the network card driver needs installing) or the port on the hub and/or hub is faulty.
To determine which item is faulty, swap network cables around, swap computers to different ports on the hub etc
Posted on Jul 31, 2009
My TI-84 calculator lost its cover for the batteries. Since then it sometimes can't turn on or show anything when I push the button "on". But sometimes it still can work. But because I havent...
Hi twylazhangzh,
Sound like your Ti 84 Plus is really over loaded and, can't function properly. You can fix that by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84 Plus. Hopefully your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer just keep following my instructions below.
First, you need to download and, install Ti Connect to your computer. If you don't need any help installing Ti Connect goto Procedure 1.
If your computer's OS is XP or Mac and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my XP or Mac OS". Just follow Procedure 1 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
If your computer's OS is Windows 7 and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my Windows 7 OS". Just follow Procedure 3 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
Procedure 1 to installing Ti84 Plus 2.55v. MP OS
1). You can also get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install.
Next, the Ti Device window should pop up and, highlight the port when found that your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Jan 12, 2011 | Texas Instruments TI-84 Plus Calculator
When ever i turn on my ti-84, it says waiting..... PLease install operating system now.
Hi biancaaii,
You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix the problem by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS. Be careful, even a power failure during the process of installing the OS will destory your calculator.
Procedure 1 to installing the latest Ti84 Plus 2.55v. MP OS
1). You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
I cannot connect my GR
Even if you cannot connect it to the computer you can still transfer applications from a working calculator.
Here is a copy of a post I wrote to answer that question.
If you have a USB SilverLink cable, use it to connect the calculator though the I/O (round) port.
If you do not have a USB SilverLink cable, you can use the mini USB to USB Direct cable but you will have to install the correct driver for it.
I do not know what computer operating system you are running and I use Windows XP so I will describe the installation procedure for Windows XP SP3.
Install TI connect 1.6 for Windows; if your system is Vista you must install a patch available on the TI website, at the same page where you find TI Connect.
After you install TI Connect, connect you calculator to the computer with the mini USB standard USB Direct cable. Windows will detect the calculator and will try to install the drivers. You will have something that is similar to what is on the three screen captures I am inserting in the post. On the last screen, choose the TI Educational Handheld device and click next.
When Windows asks to stop installation, click continue anyway
After the installation, click finish.
Device manager will show you something like what is on next screen (TI Educational Handheld device)
Run TI Connect to verify that the calculator is recognized. Connect your computer to the Internet and click the Updates Button on the TI Connect tool bar.
Jun 22, 2010 | Texas Instruments TI-84 Plus Calculator
My Ti 84 plus can't seem to connect with anything. My computer won't recognize it. My cable was inserted properly. Also, my calculator can't connect with other calculators. I know that I'm doing the...
I do not know what computer operating system you are running and I use Windows XP so I will describe the installation procedure for Window XP SP3.
Verify that the I/O port (the round one) does not contain any foreign material. Also, for transferring files batteries must be in excellent condition.
Jun 12, 2010 | Texas Instruments TI-84 Plus Calculator
Problem with Driver
Try uninstalling and reinstalling the driver. Did you check TI's website? There might be an updated driver you can use. Also, is the calculator on when you plug it into the computer?
May 27, 2010 | Texas Instruments TI-84 Plus Calculator
TI connect not working
Here is a copy of a post I wrote to answer your question.
Apr 15, 2010 | Texas Instruments TI-84 Plus Silver...
My computer won't find my ti-84
Mar 22, 2010 | Texas Instruments TI-84 Plus Calculator
My ti-84 plus sivler edition isn't working
Try to follow the procedures below to install the correct drivers (if that has not been done). Once you are able to connect it to the computer update the OS to the latest version 2.53MP. After you achieve that, go to the TI website education.ti.com to download other applications.
Feb 19, 2010 | Texas Instruments TI-84 Plus Silver...
TI84 does not work!
Perform a manual Garbage Collect.
  1. Press [2nd][0] to access (CATALOG)
  2. Press [TAN] to jump to first command that starts with G.
  3. Find GarbageCollect
  4. Press [ENTER][ENTER][2:Yes].Garbage collection may take up to 5 minutes
  5. After garbage collection is finished retry transfering data to calculator.
Uninstall and reinstall the TI-Connect software:
  1. Go to Start >> Settings >> Control Panel or Start >> Control Panel and select "Add or Remove Programs".
  2. Locate the TI-Connect software in the list and then choose "Remove".
  3. Once the software uninstall process has completed, please shut down and power off the computer.
  4. Wait approximately 20-30 seconds and then reboot into Windows.
  5. Download and install the latest version of the TI Connect software from the TI Connect Software home page.
  6. Once the TI Connect software install process has completed, restart the computer before using TI-Connect.
  7. Attempt to transfer data to the calculator.
If these steps do not solve the problem contact TI
Jan 30, 2010 | Texas Instruments TI-84 Plus Calculator
Screen displays small horizontal line when powered on that quickly fades away. Have changed batteries. When I do a reset (take one battery out, push delete while putting it back), the screen displays...
Here is what the Texas Instruments Knowledge Base has to say about your question.
I hope it helps.
Reinstalling the OS fot the TI84Plus
Howdo I correct the Error Waiting...Please Install Calculator SoftwareNowmessage on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.Themost common cause of a transfer being interrupted is updatingthe operating system on a calculator with low batteries. Users will needtouse the TI Connectivity cable and the TI Connect to sendthe operating system to the calculator. Make sure to have thelatest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If themessage "Error! Press any key to turn unit off. Then turn unit back on."appears on the graphing calculator, quickly, remove one battery from thecalculator and reinstall it while the transfer is taking place.
Oct 26, 2009 | Texas Instruments TI-83 Plus Calculator
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
209 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
