See if this link helps you out. Where is the chimes turn on off switch on older Kleinining mantel clock...
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
SOURCE: Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
SOURCE: I have a Strausbourg chime mantel clock. It chime
each press of the red button will advance the chime count by one. Advance the chime count to match the face clock
SOURCE: bulova mantel clock won't keep
Try CAREFULLY cleaning the mechanism with naphtha lighter fluid. Lighter fluid is high grade naphtha. Be careful not to allow it to run on to the face and electronics. It may damage the face with stain or remove any decals or cemented numerals. It may only take a small amount to clean the shaft bearings. The lighter fluid cleans and lubricates without leaving a film. If you can, while the fluid is on the gears, manually turn the clock forward 12 hours. That will rotate all the gears fully. Us the fluid sparingly!
