Question about LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive
I can't connect to Edmini via LAN nor USB. LAN computer doesn't detect then I tried to check edmini from browser then I get this message /www/cgi-bin/public/sharelist: line 246: cannot create temp file for here document: No space left on device I can't connect via USB because my window doesn't know the device. However early this morning I could connect it via both USB and LAN no problem. Please help!!
  • 4 Answers
Just contact www.lacie.com great support. there answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Posted on Feb 04, 2010
    Problem Solver:
  • 19 Answers
Clear browsing and Cookies, run virus system restart computer
Posted on Jul 29, 2009
HDD Rest
The LaCie Ethernet Disk Mini is an external hard drive that you can connect to your computer through an Ethernet connection.
Those who work on large projects that might require more memory than a computer has can use one of these devices to save information from the project.
Video editors often use hard drives such as these because videos often take up so much memory on their computers.
To keep information on the drives secure, change the administrator password from time to time.
Type "http://edmini" into your Web browser.
Logon to the page using your current login information. The default username and password is "Admin."
Click the "Users" tab.
Click "Change the Administrator Password."
Type and confirm the new password.
or if this fails
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Oct 29, 2012 | LaCie Computers & Internet
Value of the memory capacitor on the PCB of the LACIE EDmini v2
If the voltage and the farads are higher than the original it won't make any difference what you put in. They are not much greater than 47uf, if you think it's 10uf than put anything above that in. It will really depends on the physical size of the replacement. Get one they same size as the one that's gone and you can't really go wrong.
Jun 19, 2012 | LaCie Computers & Internet
Hello. I have a LACIE EDMINI-V2 that won't start, no disk noises, no light from led in front button, nothing. I have dismantled the box, connected the disk drive to my PC and its ok, measured the 5V and...
I owned one just like this and the power supply failed at about 1 year. It turns out it's a fairly common problem. Since you have the device open, does the controlboard/motherboard look burnt at all?
If it is not damaged, you may be able to buy a replacement power supply here: http://www.lacie.com/products/range.htm?id=10030
If it is damanged, then you may still be under manufacturer warranty, contact Lacie here: 503-844-4503 sales@lacie.com
Please leave feedback for this answer, thanks.
Mar 09, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Hi, I cannot connect my Lacie "EDmini Ethernet 400 gb" on to my laptop (dell with windows 7) via the Ethernet option? The blue light goes on but the disk cannot be found by my laptop. Could you...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Feb 02, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I am trying to connect netgear router to my modern ATT can you help me out?
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Jun 08, 2010 | NetGear WGT624 Wireless Router
TalkTalk Modem Smartax MT882 to Netgear RP614 problem
Well your modem and router IP is same thats why you can't connect your router with modem
your have changed IP of the router,please follow steps to resolved your issue
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.0.1 address bar. press enter
16. Click Apply.
Hope it can resolved your issue
Happy to help
Thanks for using Fixya
Apr 04, 2010 | NetGear RP614 54 Mbps 4-Port Web Safe...
Everytime i type my password and user name, the smiley face will begin to go yellow then turn to gray again. then a box will pop up saying that "messenger encountered a connection problem. please check the...
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, for my problem i choose broadband(DSL/Cable).
5. Control Panel > Internet Options > Connections (tab) > Lan Settings (button) then uncheck the Proxy server checkbox and check automatically detect setting
6. Control Panel > Internet Options > Connections (tab) > dial-up and virtual private Network setting > select your default connection > setting > check automatically detect setting
Please rate my response!! Thanks, SF
Jan 28, 2010 | Yahoo Messenger
We have moved and got new computer and cant find my cd for my router
Routers by default will get automatically detected by computer when connected via lan cable. Then open your browser and navigate to Router config URL (ex. 192.168.1.1) to configure your router. You need to install the drivers present in the CD if connecting via USB cable to your system. Donwload the needed driver from the router manufacturer website for your particular model.
I hope this is helpful to you
Dec 31, 2009 | NetGear RangeMax WPN824 Router
Fan keeps going, blue light always on, clicking noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Jun 28, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
No access to the disk, same clicking sound + constant light
It may not be getting enough power. Is there an external power supply you can plug in or another USB connector that can be plugged in to another port?
Jun 18, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Open Questions:
See all LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive Questions
LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive Logo
5,152 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
