Question about Volkswagen Golf V Vw Scale Diecast Model
The green light on the dash of a VW Golf, old model
I have an old VW Golf shuttle and the green indicator light on the dash comes on and flashing when I switch the ignition on. It flashes intermittently all the time until I turn the ignition off.
The indicators all work fine.
Should I be worried can this cause the vehicle to catch fire.
TIA
Pmb
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 104 Answers
I would suggest trying another cluster[clocks].The resistors on the back of the cluster could be faulty.
Posted on Aug 05, 2009
Did the 1996 1.6 citi golf Shuttle come out with a rev counter?
I'm assuming you're referring to a tachometer. Some VW Rabbits, Jettas, Foxs (precursers to the Golf) did come out with tachometers. You might find a good dash cluster with one in a wrecking yard or on e-bay.
Nov 05, 2014 | Cars & Trucks
Vw golf dashboard lights
With the key out of the steering lock the indicator stalk puts the parking lights on only for which ever side you have selected. The dash lights will not come on but when you open the door you will hear the lighs lft on chime
Jul 08, 2014 | Volkswagen Golf Cars & Trucks
2002 VW Golf TDI - Live in northern ontario - -20's with wind chill. When I first drove the car this morning - error code (looks like a clock) on upper right portion of speedometer gauge. Just flashes on ...
Classic 109 relay failure.
Relay is for the Glow Plug system.
This relay provides the power to all of a TDI's engine-based electronics.
If the glow plug light comes on intermittently by itself, check your brake lights too.
A burned-out bulb will cause the glow plug indicator light to come on. Sometimes flashing is caused by a bad Brake Lamp Switch on the Brake Pedal. It was updated for free by VW .
If you can see it under the knee panel, the Brake Lamp Switch body should be Metallic Green....if it is Purple or Black it need updated.
Jan 14, 2011 | 2002 Volkswagen Jetta TDI
2007 golf tdi has dash warning light.
hi,
i think the light you are seeing is the cruise control indicator. its not faulty , just switched on. the switch is on the indicator stalk. on later model they changed it so this light would only come on when you had set your speed.
Jul 19, 2010 | Volkswagen Golf Cars & Trucks
VW Golf Mk4 1.4 16v Oil Light Warning on Dash
Measure your oil at normal operating temp, without the engine running of course. This will give you a more accurate reading once the oil has circulated in the system.
The system works like this:
  • With the ignition on, the oil pressure indicator light on the dash should come on and flash. Once the engine is started, the light should go out and stay out as long as the engine is running.
  • If the oil pressure drops below approximately 0.3 bar or 5 psi when the engine is running below 2000 rpm, the light will flash.
  • If the oil pressure drops below approximately 1.8 bar or 27 psi when the engine is running above 2000 rpm for more than 3 seconds, the indicator light will flash and the buzzer will sound.
If either this two warnings occur:
  • The engine should be switched off immediately and the oil level should be checked.
Apr 29, 2010 | 1999 Volkswagen Golf
98 VW Golf GL, Dashboard lights out!
Remove dash and make sure main electrical plug is snapped in place .Also look for a lose ground wire.
Feb 04, 2010 | 1998 Volkswagen Golf
2001 vw golf 1.4 wiring details for towbar plug/socket.(colour coding)?
Left indicator - Yellow to Black/White
Right Indicator - Green to Black/Green
Left Tail - Black to Grey/Black
Right Tail - Brown to Grey/Red
Fog - Blue to Grey/White
Brake - Red to Black/Red
Earth - White to Brown or Body earth above/behind Left hand Light
Oct 02, 2009 | 2001 Volkswagen Golf
Red oil light flashing, oil change no problem but light still flashing noise coming from tappets are they related I have a problem on my vw jetta ? flashing light on my dash
Yes it is related, don't drive it. First thing you should do is install a new oil filter even if it isn't time for an oil change.
May 31, 2009 | 2000 Volkswagen Golf
VW Polo Dash Instrument's
buy a repair manuel from a parts store. Check to see that it has the wiring diagram in the manuel.
Jul 24, 2008 | 1985 Volkswagen Golf
Volkswagen Golf V Vw Scale Diecast Model Logo
243 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Kulu Criss
Kulu Criss
Bogdan Odwazny
Bogdan Odwazny
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
