Washing Machines Logo
Carolyn Brockert Posted on Oct 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I unlock control? - Washing Machines
NOEL
Level 3:
Top Expert:
  • Washing Mach... Master 8,606 Answers
  • Posted on Oct 27, 2017
NOEL
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2318881
Points
68630
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off. If that does not do it, try putting the machine into diagnostic mode. The washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test.2 Nov 2012
SOLVED: How do I remove the Control Locked light which prevents ...
washing machine How do unlock control Google Search
1helpful
2010 Equinox doors keep unlocking after the car is parked killing the battery
Could be any number of thing's causing this problem . Knowing what all is involved in the locking an unlocking of the doors is key . Computer controlled by the BCM - body control module , relays ,wiring ,switches etc... Bad input from switch or grounding wire to the BCM could make the BCM think door unlock has been requested .
Door Lock System Components
The power door lock system consists of the following components:
• Driver door lock switch--Provides a switched voltage signal to the body control module (BCM) for both lock and unlock switch activations.
• Front passenger door lock switch--Provides a switched voltage signal to the BCM for both lock and unlock switch activations.
• Door lock relay--Located in the instrument panel (I/P) fuse block and controls the locking of all doors and liftgate.
• Door unlock relay--Located in the I/P fuse block and controls the unlocking of the passenger doors and liftgate.
• Driver door unlock relay--Located in the I/P fuse block and controls the unlocking of the driver door.
• BCM--Class 2 module which requires programming when replaced
• Reversible door lock actuators in each of the doors
• LOCK/MIRROR 10 A fuse--Located in the I/P fuse block, supplies power for the door lock switches and relays.
• DR LCK 20 A fuse--Located in the I/P fuse block, supplies power to the relays
Door Lock System Controls
The power door lock system can be controlled by any of the following:
• Power door lock switch activation
• Keyless entry lock or unlock command
• Delayed locking command
• Automatic door lock command
• Lockout prevention command
• An air bag deployment
Door Lock and Unlock Operation
When a door lock switch is activated in the lock or unlock position the body control module (BCM) will receive a voltage signal on either the door lock switch lock or unlock signal circuits.
The BCM, upon receipt of a lock switch lock or unlock signal, will switch the appropriate lock relay control circuit(s) to battery positive voltage. This will energize the appropriate lock or unlock relay(s). The relay will supply voltage to the door lock actuator lock or unlock control circuits to one side of the lock actuator. Since the opposing side of the lock actuators are connected to ground through the other lock actuator control circuit and the normally closed contacts of the lock or unlock relay, the doors and liftgate will then lock or unlock appropriately.
Three relays are used to operate the lock. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked by itself using the keyless entry transmitter.
Automatic Door Lock Operation
This body control module (BCM) controlled feature can be personalized to driver preference.
The BCM will automatically lock the vehicle doors if the following conditions exist:
• All vehicles doors are closed.
• The ignition is in the ON position.
• The vehicle is shifted out of PARK.
The BCM will then unlock the doors when the ignition is placed in the OFF position.
The first thing ,hook up a professional type scan tool an check for DTC'S in the BCM
DTC Descriptors
DTC B3140 00: Driver Unlock Switch Circuit
DTC B3145 00: Passenger Unlock Switch Circuit
DTC B3150 00: Driver Lock Switch Circuit
DTC B3155 00: Right Front Lock Switch Circuit
DTC B3130 00: All Door Unlock Circuit
I have a 2008 Chevy Malibu inside door locks don’t work like theirs no power no does not click on inside to lock when you’re in the car nor outside when you put the key in the outside lock it only locks...
Probably not a whole lot your going to be able to do ,Unless you have a factory or some other professional type scan tool to check for DTC'S - diagnostic trouble code's , an have service repair info for power locks for your car . Computer controlled (BCM) - body control module .
The Power Door Lock System consists of the following components:
• Body control module (BCM)
• Reversible door lock actuator in each of the doors
• IBCM (PWR) 15-amp fuse
• Driver door cylinder switch, if equipped
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock or unlock actuation
• A last door closed locking (LDCL) actuation
If the driver door cylinder switch feature of the vehicle is functional, the locks may also be operated by a driver door cylinder switch lock or unlock activation
Power Door Lock Switch Operation
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5 K? resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
Power Door Lock Actuators
The body control module (BCM) powers the reversible door lock actuators by providing battery positive voltage and ground to the appropriate lock and unlock control circuits of the actuators. The Lock control circuits of the driver and passenger door lock actuators are all connected together, however, the Unlock control circuits are connected in a slightly different way. While the unlock control circuits for the passenger door lock actuators are connected together, the driver door lock actuator has a separate unlock control circuit. The system is designed this way so that the keyless entry transmitter may be used to unlock only the driver door. Despite this difference, all of the lock actuators perform much the same way. When the door lock actuators are not active, all actuator Lock and Unlock control circuits are at ground potential within the BCM. Transitioning of the lock actuators to the lock or unlocked position depends upon which control circuits receive voltage and which control circuits receive ground.
• If the BCM is commanding the door lock actuators to Lock, it momentarily switches the lock control circuits to voltage. Since the unlock control circuits are at ground potential within the BCM, the actuators transition to the Lock position.
• If the BCM is commanding all door lock actuators to Unlock, it momentarily switches the unlock control circuits for both the driver and passenger door lock actuators to voltage. Since the lock control circuits are at ground potential within the BCM, all lock actuators transition to the Unlock position.
• If the BCM is commanding only the driver door lock actuator to Unlock, it momentarily switches only the driver door actuator unlock control circuit to voltage. Since the lock control circuit is at ground potential within the BCM, the actuator transitions to the Unlock position.
Power Door Lock and Unlock Operation w/Keyless Entry Transmitter
The keyless entry transmitter may be used to unlock only the driver door. When the unlock button of the keyless entry transmitter is pressed once, the body control module (BCM) receives the unlock request from the remote control door lock receiver (RCDLR). The BCM interprets this single press as an unlock driver door request and responds by switching only the driver door lock actuator unlock control circuit to voltage. With the lock actuator lock control circuit for the driver door at ground potential within the BCM, the driver door lock actuator transitions to Unlock.
If the unlock button of the keyless entry transmitter is pressed a second time within three seconds of the first press, the BCM interprets this second press as a request to unlock the passenger doors and responds by switching the passenger door unlock control circuits to voltage. With the lock actuator lock control circuits at ground potential within the BCM, the passenger door locks transition to Unlock.
To lock all doors with the keyless entry transmitter, a single press of the transmitter lock button is all that is ever needed. The BCM receives the lock doors request from the RCDLR and responds by switching all lock actuator lock control circuits to battery voltage. With the actuator unlock control circuits at ground within the BCM, all actuators transition to Lock.
Maytag dryer control is locked. how do I unlock it?
Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light goes out when the control panel is unlocked. Also try unplugging it for five minutes to allow it to reset
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
1helpful
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
• A door lock cylinder switch unlock actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 • GE Dryers
1helpful
I bought a honda civic sport 2005 got it resprayed and i built it up and now the alarm keeps going off the key fob doesnt work etheir the battery has been flat . does any body no how to reset the fob or...
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
IMMOBILIZER CAN ONLY BE SET BY DIAGNOSTIC EQUIPMENT
2helpful
The controls locked is displayed. what causes this and how do i get the controls unlocked.
4helpful
Control locked. How do I unlock it?
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off to unlock the control. The End of Cycle button is located at the extreme right of the console. Unplug the machine for at least 15 minutes to reset the central control unit if the control cannot be unlocked using the End of Cycle button. Let us know if the control cannot be unlocked even after the machine is unplugged.
As to me to stitch the second key from ignition (with immobilizer) in memory of my car (Honda CRV-2,4 EX 2002, made in UK) if nearby is not present diller from Honda.
Programming
When
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 8 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control
NOTE THIS IS FOR YEAR 99-02
How to recode remote to vahicle
Programming
When
How
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control.
Top Washing Machines Experts
john h
