Question about Epson Office Equipment & Supplies
I have a epson 760 all lights flashing can not stop them
  • Epson Master
  • 19,396 Answers
Try removing the cartridges, then unplug printer power cord, plug back , and restart.
Test different cartridges and look inside the printer for paper or foreign objects.
Try reinstalling printer software.
If still no luck, then test the printer on a different computer, installing software first. If it does not work, then the printer is faulty.
Posted on Jul 29, 2009
  • Ginko
    Ginko Jul 29, 2009
    I will be grateful if you can change the negative rating given for my free advice. It is not true that the comment had nothing to do with your problem.
    Thanks.
All light flashing on epson stylus sx105
Epson Stylus Printers all lights flashing 1160 760 860 etc ..
just found this for you not saying it will work for your printer but give it a try.
Nov 22, 2016 | Epson Office Equipment & Supplies
All lights flashing
When all the lights are flashing, that indicates a maintenance request. for your printer. If your printer is under warranty contact the EPSON Connection Technical Support or an authorized Epson servicer for assistance. Only the concerned authorities can fix this problem in your printer.
Thank you !!
May 24, 2010 | Epson Stylus Color 760 InkJet Printer
All 4 lights flashing
Probably the waste ink tank is full.Try this:
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
Nov 11, 2009 | Epson Stylus Color 760 InkJet Printer
All 4 lights blinking
I cannot get ink printer out as it stuck in Epson Stylus color 760. I have been clean and extract waste leak ink away. The light is still blink. Sigh
Apr 09, 2009 | Epson Stylus Color 760 InkJet Printer
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point.
May 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson 760 Problem
I found this procedure to work for the Epson Stylus 760 printer. The error is indicated by all four lights on the printer flashing and appears to be caused by the internal counters of the machine being exceeded. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
1) Turn off your printer, ensuring that the print head is at its home location and locked in place as normal.
2) Remove the four screws securing the top cover two at the rear and two at the front under the lift up cover and lift the cover off.
3) Remove both ink cartridges.
4) When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer’s power switch was ‘on’ - switch it off and return to step 1.
5) Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down.
6) When the paper-out LED flashes, release the buttons.
7) Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button).
8) The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
9) Insert the cartridges as normal and replace the cover.
Mar 13, 2008 | Epson Stylus Color 760 InkJet Printer
55 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
