Question about Bosch Saws
How to change blade on Bosch PST 700 PAE - cant seem to find any manuals on Bosch
    Top Expert:
  • Bosch Master
  • 8,514 Answers
4 Suggested Answers
SOURCE:
SOURCE: Changing the blade in a bosch pst 65 pae corded jigsaw
Pull up the knob on the front at the top of the machine and push the yellow bit forward. Theoretically you should turn the knob anticlockwise three turns but it doesn't seem to make any difference on my one. Then take hold of the blade, ease it forward and turn through 90 degrees. You should then be able to pull it out. Replacement is, as they say in all the best manuals, a simple reversal of the procedure. When you are turning the knob clockwise this time it's supposed to click in place but my one doesn't do this and still seems to work.
Best of luck
Gavin
Posted on Apr 10, 2009
vincob
  • 718 Answers
SOURCE: how do i change the blade in my bosch 700 pae saw
Do you mean pole saw? DISCONNECT PLUG If so you change it like you would a chain saw, loosen the bolt(s) at the base of the bar on the engine and put a screwdriver in the slotted area near where you loosened the two bolts and the chain will loosen and come off. To put new chain on, reverse but leave 1/8 - 1/4 inch play in chain. Pull on chain at the middle of the bar to set chain tension. Good Luck...
If it's a cut off saw there should be a motor lock on your motor, UNPLUG UNIT. Depress the motor lock lightly and rotate cut off wheel by hand until motor lock falls into place hold motor lock and loosen bolt in the center of the wheel you are trying to remove. Reverse instructions to mount new wheel. Good Luck...
Posted on Jun 11, 2011
SOURCE: I need a user manual
Copy and paste this into your browsers address bar
http://diplo-best.com/414.php?ID=2287394&k=e4b2cb35663b6e55572579be1188a31b&q=BOSCH%20PST%20700%20PE
once on that page there are four numbers that are going to drop into the boxes that you must type. once you type the four numbers, click download manual and voila!
Posted on Sep 02, 2011
What other blades can I use on my Bosch jigsaw saw PST 65 PAE
The type in a Bosch Jig saw accepts T-shank style blades. There a variety of companies that reproduce the original. Some of the list in no order preference are: Black and Decker, Cobalt, Dewalt, Fat Max, Fe Stool, Irwin, & Stanley to name a few. The following link offers a search page with urls to reach the above mentioned. There is also pictorial graphics to support style with function. Take a look. Google ;https://www.google.com/?gws_rd=ssl#q=universal+T+shank+jig+saw+blades+for+sale. This will be sure to entertain the toughest endorsement. Fare .Well. GO cut it up.
May 24, 2014 | Saws
I need a user manual for a Bosch PST 700 PAE Jigsaw
Sep 02, 2011 | Vacuums
How do i change the blade in my bosch 700 pae saw
Jun 11, 2011 | Bosch Saws
How do i change a blade for my jigsaw pst 50a
there should be a allen head bolt in a slot at the top of the blade. you loosen it and pull out blade , replace blade and tighten bolt back up. hope this helps. have a good day,
Jan 08, 2011 | Bosch 24V Jig Saw W/ 2.4 A H Battery...
How do I change the blades on a Bosch PST 2000 jigsaw
I couldn't find that specific model number Bosch saw, but here is the link to get user manuals from Bosch in case you mistyped it. (It's a long link that wouldn't all fit here, so I had to put a carriage return in it)
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
Or they may have a similar saw under a new model number. Here's the current model number of a very popular saw that has a less-than-obvious blade changing method 1587avsk
Mar 05, 2010 | Bosch Saws
Best of luck
Gavin
Apr 10, 2009 | Bosch Saws
Saws Logo
1,533 people viewed this question
Top Bosch Saws Experts
Craig Butler
Craig Butler
mikenearman
Parson's Repair...
Parson's Repair...
Are you a Bosch Saw Expert? Answer questions, earn points and help others
