Question about HTC S620 Smartphone
On / off bytton not working
My "on / off" button not working. Tried batteries in another 620 and they're fine. Please help.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sniper:
  • 68 Answers
Power button is not work so please change this button from nearest shop.
Posted on Jul 29, 2009
Ducati 620 wont start with new battery
Hi, Efrensaunder and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have nice a day.
http://www.ducatimonster.org/forums/tech/205386-2006-monster-620-wont-start-just-clicks-when-i-press-start.html
Monster 620ie not starting help Ducati DUCATI 620 MANUAL SERVICE REPAIR FSM 2002 2006 DOWNLOAD Download Manuals...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Jun 12, 2012 | 2003 Ducati Monster 620s i.e.
I have a 2002 Ducati 620 that will not start. All lights and guages work and the motor turns over but will not fire up. Help!! Thanks, Brian
Hi, Branda844 and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
2005 Ducati Monster 620 Wont Start
My 02 620 won start
2004 2006 Ducati Monster 400 620 Motorcycles Service Repair Manual Highly...
Ducati Maintenance
May 27, 2011 | 2005 Ducati Monster 620
I have a Dell Precision 620 and the problem with running a PC. When I press the button, only yellow light is present and nothing happens. Control LEDs (4 pieces) on the rear side of motherboard does not...
Having worked with Dell computers before I have found that the amber light usually means bad power supply.
Get a replacement power supply from a know working Dell machine as their power supplies are different from standard ATX power supplies.
Regards.
Jan 13, 2011 | Dell Precision 620 PC Desktop
I have an hp 620 laptop which i bought just recently.It was working ok for the last 3 months until today when i was working, using the battery coz it was 87% charged.The laptop went off just after it...
Compaq 620"?
that charge, data is useless, ill tell you why later.
does the LT run with no battery? never post lacking this fact.
IT must, or the power pack is bad or the PC is bad.(ask)
this is always test 1, if yes, the battery bad.
never seen any battery this old good,
not one.
I guess this is the old Compaq 620 that HP mutated to HP 620
no service tag presented so ,no really good answers possible
"I tried to take out the battery and leave the laptop the whole night without the battery, but still my laptop does not come on. (tried?)
so does that mean the battery is out, or in.? NOW?
try to be clear, as we can not do the simple tests nor watch you do them.
runs on wall power pack, A/C line 19vdc power pack.>?no battery.
IT MUST OR THE PC needs service. (or the A/C pack is weak(bad)
pC is like 2010 year. no battery lasts this long,
if the PC is dead, with no battery , with power pack only used,
then see here, for black screens, or dead BIOS.
http://pcdied.com/
Mar 27, 2017 | HEWLETT-PACKARD 620 XT964UT Notebook PC
Dell 620 battery and charger good stll will not charge
Bad? Most likely, that laptop is pretty old, (at least 2 years) surprised that it lasted that long. Sorry, no disresprect, but they are only available as outlet. Of course you can still get support and downloads from Dell.com. Also you can still get batteries, power supplies and etc. (I do not work for Dell.com, nor advertise any of their products) Not that this will do you any good I think. It seems as though the actual module that your power supply plugs into is bad....Imagine that. It's a dell, not the first or last time that I had to buy a new power supply or that happened to me. Also it has somewhat to do with the power surges from the plug that you are in...Please I rather not get into that. Sorry I can't be of any more help. I my opinion, your original thought is pretty close to your solution. Let me know..m_nastasi@hotmail.com
Aug 13, 2009 | Dell Latitude D620 Notebook
Ducati monster 620 went dead
sounds like ya blew a fuse check em first check for inline fuses too
Aug 05, 2009 | 2003 Ducati Monster 620 i.e.
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
HTC S620 Smartphone Logo
75 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
