Back to:
Tags:
Kenwood KDC-C469FM 6-Disc CD Changer
Cannot unlock
posted by Moonbeam on Nov 23, 2007
My car went into the garage the other day and they disconnected the battery, resulting in the stereo locking. No problem I thought. I have the little unlocking device but this time it wouldn't transmit so I changed the battery in it and it still will not work. Is there any way of unlocking the stereo without the device? Please help it is SO boring driving without the radio!
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 14, 2007
Helpful (85)
robotek
Rank:Guru Guru
Rating: 90%, 675 votes
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on cannot unlock:
I don't want to Accept this solution
Can you Help with these Car CD Changers problems?
Car CD Changers
2006 Merc C180 Coupe with Harmon Kardon system. How do you...
Car CD Changers
Never received a manual when we bought the car for...
Car CD Changers
I removed the fuse and replaced it. Now it does not even...
Car CD Changers
the prior owner had a cd 10 disc cd change installed and...
Car CD Changers
I have a 97 honda civic DX. I have installed a new...
Loading problems.
Repair Service
Find Car CD Changer Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
