When I connect to the internet I get a box appear with the message:- Resolution notifier optimal resolution 1024 x 768 refer to users manual, as I do not have a manual I wonder if someone has the answer
    President:
  • 1,383 Answers
Go to control panel and then dispaly -> settings then change screen resolution to 1024*768 .
Posted on Jul 29, 2009
My frontech lcd tv box model no.jil 0622 is display d-sub out of range 55.9khz/59hz
Your computer is showing a resolution that the screen does not support. Look up the optimal resolution of the screen online , boot the PC to safe mode then select the correct resolution in display settings
Sep 27, 2017 | BOX Computers & Internet
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
I continully receive a message of the screen is not in optimal mode of 1920X1080. I have gone to the screen setttings and have applied this yet I continue to receive the message when I go to play a game....
Your game does not natively run at the same resolution as Windows. Check the video/graphics settings in the game itself to adjust the resolution to 1920x1080.
Note that increasing the resolution to this, will drastically increase the load on your graphic card.
Feb 26, 2011 | Samsung SyncMaster 2233SW Monitor
Osd menu popping up ..how do I stop it
just to make sure we are talking about the same thing, when talking about the OSD (on-screen display) that normally refers to the monitor only, such as the menu to adjust horizontal positioning, or the mode (digital or analog) setting. Is that what you are talking about? If so, what does it say?<br /> <br /> Did this just start? Have you recently changed resolution settings? I note in your manual the following warning:<br /> <blockquote><font color="Navy">The On Screen Display manager also features pop-up<br /> warning messages for certain situations, such as if you<br /> attempt to set the monitor resolution outside the<br /> recommended range.</font></blockquote>It also says:<blockquote>Your monitor is optimized for 1024 X 768 @ 60 Hz. </blockquote>Are all cable connections secure?<br /><br />And if you right click on the Desktop &gt; Properties &gt; Settings, what is the resolution set to? 1024x768 it will be ok<br />
Aug 30, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Input Not Support
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears. If you use Windows Vista oder Windows 7 you can access the resolution windows by right-cliking on your desktop and selecting "Screen resolution".
Jul 18, 2010 | AOC 19LVWK LCD Monitor
My blackberry 8310 show jvm error 102
Cause 1:- There is no MX record for the Internet domain associated with the BlackBerry Enterprise Server user. Error 1 appears.
Resolution:- Create an MX record for the Internet domain. Make sure the computer running the BlackBerry Manager is pointing to the correct DNS server.
Cause 2 :- Incorrect DNS settings
Resolution :- Ensure the computer running the BlackBerry Manager is configured with the correct DNS settings.
Cause 3 :- BlackBerry Manager is not allowed to make a direct SMTP connection to that mail server.
Resolution :- Configure the mail server referred in the MX record to allow the direct SMTP connection from the BlackBerry Manager.
Thanks for using fixya.
Oct 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Message received is "Resolution Notifier best resolution is 1280*1024 notification keeps appearing on monitor and I cannot get rid of it. the picture appears fine, why does the message keep appearing?
This is similar to the "out of range" message that many flat monitors give when the resolution is maybe higher than the monitor would like.
It has given you the suggestion for a good reason. As with most monitors flat or crt it is possible to shorten the life of them if you abuse them in this way.
My suggestion is to lower your resolution to the one it offer you.
Aug 25, 2009 | NEC MultiSync LCD175VXM-BK (Black) 17" LCD...
WHEN I CONNECT TO THE INTERNET I GET A BOX IN THE MIDDLE OF SCREE
The recommended entry resolution is 1024X768... do you have your computer set to 800X600 or below ?
This is usually why you get this message.
go to control panel/display and check this.
Jul 29, 2009 | NEC MultiSync 1940CX 19" LCD Monitor
AOC 771S monitor always appear "not support out of range even if i already set my resolution to lowest.
the lowest resolution is not always supported. by the range maybe referring to the frequency. change that, that should work. if you are not sure, look at your monitors manual, it will tell you resolution as well as frequency optimal settings
Apr 20, 2009 | Computers & Internet
NEC 1940 CX Monitor
Here's the user's manual: http://www.necdisplay.com/cms/documents/UserManuals/17401940CX_053106.pdf Basically, according to the manual, you have to go into your menu and turn off the resolution notifier.
Jun 15, 2007 | NEC MultiSync 1940CX 19" LCD Monitor
Computers & Internet Logo
189 people viewed this question
David Payne
David Payne
