SOURCE: Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
SOURCE: K?ppersbusch KD9400.0GE Kitchen Hood SPARES
go the company web address and they will assist you.
www,kupperbuschusa.com/Hoods.asp
good luck and please rate my answer. thank you.
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
