Question about Dell Dimension 2300 PC Desktop
My Dell Demension 2300 will not power up.
If I unplug it and plug it back in the case fan will start to run and than it stops. The fan will only run for about a second and than it stops. Also the light on the cdrom will blink one time and than it stops. Any help would be great.
    President:
  • 1,383 Answers
Open cpu cabinet then refix RAM.
Reattch all connection to motherbord also check your smps power unit works fine.
may be your smps is gone .
SMPS is aquare box which with you connect power code.
Posted on Jul 29, 2009
Dell Demension 7100with Intel Celeron won't start
do you have any light or fans running, if not check power supply, if you have heard a whirling sound lately it could be your fan dies and burnes up the supply, not hard to fix,lightning can cause this also through the network or phone, just takes one hit in the ground to lock up the diodes in the power box, most cost about 40 buck at the computer store, warning the dell named one will be high, not nec as good, Matt
Aug 03, 2015 | Dell Computers & Internet
Where is the wps button
some routers dont have wps button but if you need to reset router To restart the Dell TrueMobile 2300 Wireless Broadband Router, unplug the power connector and plug it back in.
To load the Dell TrueMobile 2300 Wireless Broadband Router's default settings, hold down the reset button on the router for at least five seconds. While the unit resets, the Power light blinks.
Jan 06, 2013 | Dell TrueMobile 2300 Wireless Broadband...
Dell PowerEdge 2300 Server won't boot
To power off using the power button, press and hold in for more than four seconds.
However this is not solving your problem of not booting, needs some more information. Such as Beeping noises, number and length of beeps. Or any LED.s flashing?
Aug 16, 2012 | Dell PowerEdge 2300 Server
Fan runs fast will not stop no monitor. computer was shut down correctly the night before. when turned on the next day fan started running very fast and still willnot stop.dell could not help from the...
Pull the power from the PC. unplug anything connected that has power. Printer, scanner, network, etc.. Open the case. (Depending on model, may be a slide catch and pull case apart like a **** shell, Or maybe 2 screws on the back of the left edge, then slide the panel back about 2 inches to release)
Remove the memory sticks, by pushing on the clips at the ends to pop the stick up.
Reseat the memory by carefully pushing them back into the slot. Make sure they go in same way, and push firmly till clips clik into place.
Plug in only the power to PC. Try to restart.
If still does same thing, it's possible the power supply module is defective, OR you need to reseat the CPU, which requires much more care and fresh thermal paste.
OR there's somthing else wrong.
Jan 08, 2011 | Dell Computers & Internet
It will not start even after I replaced the power
Before anything else, open your case and make sure all power and data cables going to motherboard, disk drives, etc are firmly seated, and remove and re-install memory sticks in the same locations. Sometimes temperature changes inside the PC can cause these connections to loosen. If that doesn't fix it, do you hear the noise of the cooling fans coming on? If you do, check your monitor for a green light. If you get a green light on the monitor and fans are powered up and running and you get nothing else it could be a hard drive issue. Try booting from CD in that case. If fans come on briefly and then shut off, or fans stay on and you have no green monitor light, this could indicate an issue with your processor or motherboard.
Jun 04, 2010 | Dell Dimension C521 PC Desktop
My cd burner will not burn cd's on my dell demension 2300
The dell system comes with the a Dell Resource CD , that has inbuilt diagnostics . Run the diagnostics to on the cd drive to check if the hardware is working fine
You can use the following link to troubleshoot the issue
http://tinyurl.com/yepmewg
Thanks for using fixya
proton
Mar 15, 2010 | Dell Computers & Internet
Can't find male side for P7 plug
dear,
maybe the fan is connected with pc source male jeck..check it by the way...
Jul 06, 2009 | Dell Dimension 3000 PC Desktop
Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Apr 24, 2009 | Dell OptiPlex GX620 PC Desktop
DELL DIMENSIONS 2300 COOLING FAN
Your system will run fine until the processor starts overheating... why not just replace the fan?
Oct 26, 2008 | Dell Mini Fan. Dimension (W x H x D) in....
PC not starting
Sure hate saying this but your dell 4400 board is the trouble.
Just finished reading a bunch of post. Double check Dell's web site too. No lights lit on the back of the PC means no power & the green led you see on the board is telling you that the board has power.
Seems your not the only person with the same problem as with other 4400 owners.
One user called dell & stated the problem he had, (just like your problem), to the letter. Dell admitted there is a problem with the 4400's. mainboard. Dell does not go out & replace every board. They, like every company wait till someone has this type of problem & contacts the Mfg. Your 4400 was made back in what 2003 - 2004. If Dell still supplies your board the best they'll do is sell you a refurbished board.
I think your better off buying a new board & fitting into your Dell case. You can try to find a board that will run your current componets.
This is dell's web site link for the dell 4400.
Good luck & thanks for coming to FixYa.
Mar 08, 2008 | Dell 8P779 - System Board Motherboard
Dell Dimension 2300 PC Desktop Logo
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
