Question about D-Link DIR-300 Wireless Router
Hi I cant configure my router D-link DIR-300
Hi
I cant configure my router D-link DIR-300, i keep getting error 322! I go through the wizard and when it comes to "detecting router" i keep getting the following error
Error 322: New Router Not Detected
Setup Version: 4.6.8127.0
Model: D-Link DIR-300
Firmware version:
I run window xp on my laptop.
Thanks
H
  • tommya300
    tommya300 May 11, 2010
    hardwire with cat5 and try that http in
This definitely worked for me. To find out your computer's MAC address, just go to start, then click run, then type 'CMD'. When prompted, type 'ipconfig/all'. Find your ethernet adapter local area network connection, and underneath you will find a lablel titled Physical Address. This is your MAC address and should consist of 6 pairs of number/letter combinations. Then connect your computer to the modem, eithe wirelessly or directly and point your browser to 192.168.0.1. Under Setup click Internet Setup and then click Manual Internet Connection Setup. Under Internet Connection Type, select Dynamic IP (DHCP), then under MAC address, type in the MAC address of your computer. Click Save Settings and Presto! It worked for me.
Posted on Nov 26, 2009
  • 404 Answers
Hi! I will be more than glad to assist u in this concern..Please dont use the setup cd or setup wizard. you can access the setup page of the router by typing at the url:192.168.0.1 then it will ask for the user name and password, by default the username is admin and the password, leave it blank.. here are the things u need to check before u setup u router.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Posted on Aug 09, 2009
I cant get a internet connection with dlink dir-300 (cable or wireless), pls help, it's working when i tried with different router...
Welcome to FixYa! In regards to your problem there are possible options you could follow. 1. Check first if your computer is detecting the router. Go to your Network Connections and see if its detecting a connection with the D-Link router that you have. 2. I suggest go to this site that has a manual for setting up a D-Link DIR-300 Wireless Router.Check if you missed any of the process. Steps: Go to Google.com then type "cant get a internet Problem with the D-Link DIR-300 Wireless Router" and then look for DIR 300 Wireless Router Manual. There you will find all that you need in setting up your router. Hope this helps! Thank you for using FixYa!
Jul 04, 2011 | D-Link DIR-300 Wireless Router
How to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
7. Turn on your computer.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
Click Launch Internet Connection Setup Wizard to begin.
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
Apr 20, 2010 | D-Link DIR-855 Wireless Router
D-link dir-300
Ensure that the router firewall is not blocking the http port 80.
Have you configured the router to open your utorrent port?
Have you set up specific strict rules?
Mar 05, 2010 | D-Link DIR-300 Wireless Router
How can i configure my d link dir 300 on my
start - run- type in cmd- enter- type in ipconfig /all will show router address should be 168.192.1.1
open internet explorer and type that # in the address bar
should connect with router
leave password blank or type in password for the password
enter the router setup and configure router to your preferance
Feb 18, 2010 | D-Link DIR-300 Wireless Router
Error code 322 cannot find router, after following installation intstructions.
Try manually entering your setup information (login) for your router and see what happens. Don't use the auto configuration wizard..
May 12, 2009 | Linksys Wireless-G Broadband Router
I have a dir 300 router that when i try to hook it up it i cant
 Let me clarify this  your internet works when your PC is hooked up directly to the modem....
When you connect the router between the pc and the modem the internet does not work....
This sounds like the configuration settings inside the router need to be setup or adjusted.
Go to the web browser and type in 192.168.0.1 and for the username type admin and then leave the password blank hit enter and it should sign you into the router. Follow the setup wizard and everything should work just fine.
Hope it Helps!
Apr 12, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
How to install D-link DIR 300 for MACBOOK
You shouldn't need to install anything off the CD. Simply plug your Macbook into the DIR-300 via ethernet (making sure you manually set your Macbook's IP to 192.168.0.x (where x is anything from 2-254). Then open up your web browser and type 192.168.0.1 into the address bar. This will log you into the DIR-300 (I think the default login is "admin" with no password).
Refer to the manual for the configuration for the rest of your setup.
Jul 20, 2008 | Computers & Internet
D-Link DIR-300 Wireless Router Logo
2,869 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
