Question about Whirlpool Washing Machines
Whirlpool awo 3751/5 will not spin
Machine is set for spin, door is locked, push start button and pump activates and drains residual water for approx 20 seconds, machine then stops and will do no more . door lock indicator light is flashing.
have checked all drains/hoses/filters and there is no led fault display showing in window. i would say it was a door lock problem but anyone who has had this problem before may be able to advise further thanks
    Scholar:
  • 51 Answers
There is a locking coupler on the Whirlpool washing machines that locks when it kicks into spinning cycle. I am guessing here, but if you try and run it without any clothes in it, it will probably spin. It will be slow starting, but it will probably spin.
The coupler is located down by the motor and is three pieces. They made it out of plastic, and while it typically holds up very well, they do break. I will try to look up the part # you need to fix it. (assuming this is your problem)
Thank you for contacting www.Fixya.com
Posted on Jul 29, 2009
My washer WFW70HE was started with the water shut off, now the door lock flashes, it sounds like the pump is running and none of the buttons including power will work. I have unplugged and re plugged?
Try resetting by pushing "Wash Temp", "Spin" and "Soil" buttons 3 times. Also be aware that your model may automatically run the drain pump for approximately 10 minutes when it is first plugged in. Let me know if you have success with that.
Apr 11, 2015 | Whirlpool Washing Machines
AWO 3751/5 - Washing machine; machine won't go past the sequence
Best to select the simplest program from the table in this document and see where it stops.
http://docs.whirlpool.eu/_doc/501930105698GB.pdf
Also check the troubleshooting section from the attached instruction manual. Most likely the water inlet valve might be playing up.
http://docs.whirlpool.eu/_doc/501930105536aGB.pdf
Sep 02, 2014 | Whirlpool Washing Machines
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Whirlpool awo 9663 wont start cycle
This can be due to failure of motor components or the control panel as there is no communication for the drive . Check the motor to panel wiring, check the panel for failed component
Jul 05, 2012 | Whirlpool Washing Machines
I have a whirlpool awo 3751/5 During the spin cycle it showed up with F09 error, I've switched to drain cycle now and it keeps displaying FP I have opened the filter cartridge at bottom and there...
Remove power for a while and allow the machine to reset. Now it is important that the drain pump be removed and checked to see if there is any dirt trapped and causing the pump to overload. Also check the inlet flow , if low it must be removed and backflushed to improve the flow. The door swithch must be checked as also the water level switch. Make sure that after removing the panel that the connections to the program module is intact. Finally check the motor drive , check for free movement of the agitator, if not check this assembly , the belt, bearings and the shaft.
Sep 27, 2011 | Washing Machines
Have a whirlpool AWO 3551 washing machine. Door locked light flashes and machine stops at random points in the program. Pump works OK and drains water. Don't suspect door lock module as washer works on...
My daughter had the same problem for about two years. A repair man came out and told her to call the company and tell them she wanted it fixed under a recall. She said the computer board had to be replaced and it was recalled due to a flaw in the machine. The service man came back again after she called, and he fixed it for free.
Jul 16, 2011 | Whirlpool AWOE8748 Front Load Washer
WhirlpoolGB AWO 3751 Door firmly shut but red door locked indicator starts to flash and programme will not start.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool awo 3751 washing machine when i close the door set the program press the start button the machine appears to start and the time reduces but there is no water going to the machine i think...
You most probably have a faulty water inlet valve...Not an uncommon problem..They can sound ok, but when you check the detergent drawer there will only be a trickle..Replace the inlet valve...Good luck...Nomess
May 20, 2010 | Washing Machines
Hi, I have a duet washer that won't turn on. The "Control On" button is blinking and when I press the "Hold to Start" button, nothing happens. And ideas?
Open and close the door.
The door has to be opened between wash cycles.
Check the door switch/lock unit
using the diagnostics listed below.
If door is locked, Drain the unit.
Check wire harness for connections.
Check the touchpad/LED assembly.
Starting the test mode:
Close the door
Press Control On button
Select the DRAIN/SPIN cycle
Select NO SPIN by pressing the SPIN SELECT button,as needed,
Push Prewash Option button 4 times within 5 secs.
C:00 will show in the display.
To advance to the next step
Push Prewash Option button 2 times.
Here are the codes:
C:00 check door lock system actuator
C:01 Check cold water inlet valve flowmeter
C:02 check dispenser motor
C:03 check hot water dispenser
C:04 check basket rotation MCU,Motor
C:05 check heater sensor
C:06 check Drain pump
C:07 check Motor or motor control unit
C:08 check Motor, MCU control
Dec 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
382 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
