Question about Samsung LN32A330 32 in. LCD TV
Tv loosing channels every time i push my tv remote to channel 1
If i put my tv remote on channel one i get channel 2 on the tv and then i loose all the othe stored channels so then i have to auto search and save all channels over again
  • Anonymous Mar 18, 2014
    Older sanyo tv will not SAVE the channels after searching
  • 44 Answers
It can be some problem with the remotecontrol, try to config the control and check the code to it, i'm sure you'll be able to find the code on the internet. Good Luck //David
Posted on Jul 29, 2009
TV is on but when is off after sometimes and next time it can't on but it is on sometimes
The cat is not sleeping on the remote by any chance?
My set sometimes does not come on. The reasons generally are:
1) I have turned off the power at the wall.
2) I have not pointed the remote at the TV but rather at the DVD player.
3) Someone pressed DVD on my universal remote and that took it off the control settings for TV.
4) The battery is loose in the remote after someone dropped it.
5) The battery is weak.
6) Someone turned off the TV manually using the switches on the side.
7) The little computer in the TV has become confused by a user trying to switch from channel to channel before each channel is "found" and displayed to screen. You turn it off and back on and proceed slower.
8) The station transmitter is off the air due to power failures.
Aug 26, 2015 | Televison & Video
How do I put this tv on channel one? The instruction on the new remote I bought says to put tv on 1 and I can't get tv to go to channel 1.
from what I understand all TV's start with #2 channel 1 is reserved for emergency freq. . ur instruction might mean put remote in TV1 mode instead of TV2 mode , incase it is like a dual remote..
Jan 14, 2015 | Televison & Video
My tv is locked how do i unlock it
Turn the TV on, hold the display button on the remote until the screen goes black. Turn off the TV and back on and it should work. Hope this helps! =]
Mar 03, 2011 | Jensen Q2749J 27" TV
I don't know how to put the tv on video
Tries pushes the tv manual button channel up a few times,tv will to go into the Video mode 1 or 2 for most of the analog tvs.Or look on the bottom front of the tv frame bazel for a manual buton said VIDEO.Pushes that manual VIDEO button to get in video modes 1 or 2.U have ur original remote have a button said INPUT pushes that button a few times to get into Video 1 or 2.
Mar 02, 2011 | RCA 14F512T 14" TV
We lost remote control for our Orion 27" Television. Trying to switch input from Antenna 1 so kids can use XBox
Tries use the front or right side panel manual controls panel.Use the Channels buttons UP/DOWN push the channels UP button couple time.U should get in Video 1 or 2 which ever ur video game console hook in.Or your tv might just have a manual video button,put that u in video 1 or 2.Try website 1-800-remotes Factory original to buy an exact remote ur problem solved.None the solutions,help.
Apr 03, 2010 | Orion STV2763 27" TV
How do I tape onto a vhs from analog tv with converter box?
There are 2 options-
Option 1
Connect the coax cables in the following order.
1 From the wall to the input of the converter box.
2. From the output of the converter box to the input of the VCR.
3. From the VCR to the TV input.
Here is how you record with this option.
1. Tune the converter box to the channel you wish to record.
2. Turn the channel on the VCR to channel 3 or program the VCR to record channel 3 this will record whatever channel you have your converter box set to at the time of the recording.
Option 2- (will not work on satellite)
1. From the wall to a 2 way splitter (made for digital cable. General rule of thumb with digital cable is gold does not usually mean good.)
2. One output from the splitter to the converter box and the other to the input of the VCR.
3. Connect an Audio Video (RCA (yellow/red/white cable)) from the VCR to the TV input.
4. Select the appropriate input on the TV for the VCR.
Here is how you record with option-
Tune the VCR to the channel you wish to record and push the record button or program the timer to record the channel and time that you wish.
Note- with this option you will only be able to record channels that you would receive without the converter box. Also each time that you split the cable line you loose part of your incoming signal and depending on how you house is set up this option could affect the quality of your digital signals on the converter box.
Jan 02, 2010 | Mitsubishi VS-55707 TV
Tv does not respond to remote commands
You need to isolate the problem.
1) Unplug the TV for a few seconds and then plug it back in.
2) Operate the TV with the buttons on the TV. (Channels etc) I presumed you have scanned in the channels.
If no problem found then do this for the remote.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Now try the remote to see if it works. If it fails you will need a new remote.
Mar 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
Dec 15, 2007 | Toshiba 27D46 27" TV
Can't change channels!!!!
take the batteries out of the remote...now check if you can change channels manually on the big screen. if so the remote is stuck on one signal that channel u said. get a new remote. if still same trouble on big screen look hard at the buttons and make sure none are jammed. also try to get to your setup menu and auto-program the channels it should search everything and then try changing channels. new stuff alot times plugs come loose, goes back to the factory workers...not pushing them tight have a tech check that at your home.
Aug 18, 2007 | Samsung PCJ522R 52" Rear Projection...
Samsung LN32A330 32 in. LCD TV Logo
173 people viewed this question
Jerry Greenberg
Jerry Greenberg
