Question about LG Shine KE970 Cellular Phone
My doughter's KE970 have the next trouble: when i push the "power on" key, the phone is run his starting sequence until ask the PIN code but i can not enter this code because the phone is starting from the beginning the same sequence until ask the PIN code, again and again. This it happens after the phone was connected to computer via usb cable for mp3 file transfer between 2 devices.
I need a PUK code for KE970
Dear Sir.
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
PIN and PUK codes are all service provider (Your SIM / Your Connection) dependent, you can never get it from anywhere else, never get fooled by anyone.
All you have to do is to call your service providers via some other phone or land line and talk to a CSR, ask him for the code. He will first authenticate your ownership and will give you your code in return, for free.
Regards.
Mar 14, 2011 | LG Shine KE970 Cellular Phone
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
SPECIAL TESTS
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
keys:
Press Keys Special Test/ Function
wrinkle
release Diagnostic Codes
dryer
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
Number
very dry(< ) View current cycle
temperature (Co)
start/pause
Start or pause cycle running
but remain in Diagnostic
mode
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
dry
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
www.appliancehelponline.com
Mar 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Entered PUK 00000000 then it asked me for my new pin code,what do i do??
the new pin code means you should enter any pin code of your choice.
Any pin code you enter at this point will be what your phone will recognize.
So you have to forge a pin code that you can easily remember. If possible write the pin code out in your dairy so that you can fall back to it in case you forget the pin code.
In summary, the new pin your phone is asking of is telling you to forge a pin code.
Good luck.
Mar 08, 2010 | LG Shine KE970 Cellular Phone
How to check the trouble codes on a 2001 chrysler concorde 2 7L
I assume you are asking about the "check engine" diagonstic codes.
You can check the codes yourself by using the key and ignition switch. With the engine off, put the key in the ignition and turn it ON-OFF-ON-OFF-ON -- do not turn to the extreme right "start engine" positon, but to the last click just before the start position.
You will then see a code list read out where the odometer (mileage) usually displays. It will start with dashes in the readout "-------", then each diagnostic code will appear in sequence like P1684, P0700, and then the word "done" after all of the codes have been displayed.
One word of warning -- I have found that sometimes all of the diagnostic codes do not display with this method, so it would be best to also check the codes using an electronic diagnostic code reader. You can do this for free yourself as explained below.
Go to your nearest "national chain -- do it yourself" auto parts store such as Auto Zone or Advance Auto. Ask to borrow the "engine code reader diagnostic tool" -- you will have to give them your driver's license to borrow it. Then, in the parking lot, check the diagnostic codes yourself.
Turn the car key to the "accessory position" -- i.e., not started, but with the accessories on. Power on the diagnostic tool. Plug the attached pin connector into the Chrysler diagnostic socket located just under the dasboard below the ignition switch. Press the "read codes" button on the diagnostic tool -- you will see a diagnostic code and a brief message about what it means. Keep pressing the "next" button until you have read all of the codes.
P.S. Don't forget to get your driver's license back when you return the diagnostic tool!
__
tekwize
www.topcashideas.com
Nov 08, 2009 | 2001 Chrysler Concorde
Callcost pin number
ou need to call the phone company that sold you the phone card to unlock the phone.
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the puk code from a database for free.
In your case you need to contact your SIM card phone provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore
Jul 11, 2009 | LG Shine KE970 Cellular Phone
I tried to set a pin for my phone (v720) and now i am locked out
am sure you didnt put in the pin correctly becus if you did it wont say that. you know what, try writing down the pin you want to use before attampting it again so that you wont forget it. it might help. thanks
Jul 03, 2009 | LG Shine KE970 Cellular Phone
I need the puk code for the orange network lg shine ke970
The PUK code is a code associated with the SIM card and not with the phone.
You have only two ways to get rid of the PUK code. Either you replace the SIM card , or you call phone provider that issued the sim cadr (eg. At&T, Virgin, Tmobile , Vodafone, Telecom etc.)
You need to call the phone company that released the SIM card, they can retrieve the PUK code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
Jun 07, 2009 | LG Shine KE970 Cellular Phone
I have a nokia 5200 and i dont know the puk code
You need to call your phone service company, they can retrieve the puk code from a database for free.
If you replace the SIM card with a different one, then the phone should not ask for the PUK anymore.
Mar 06, 2009 | LG Shine KE970 Cellular Phone
My daughters phone keepsmlocking up
the problem might be it would have asked PUK code or PIN code and ur daughters would have tried some random number. thats why ur mobile has been totally locked. its better to get the PUk code from ur mobile service provider.... pls rate me
Jan 18, 2009 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
65 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
