Question about Samsung TXN3271HF 32" TV
I have samsung 21 green screen
I have samsung 21" TV (CRT), screen look green, exp. skin, face people, but when I give some magnetic speaker, like radio in front of CRT tube, the color look normal, but not all. Just when it near from magnet.
  • 27 Answers
Try to defrage the picture tube with a magnetic field coil - if not - tube are damaged and need to be replaced
Posted on Jul 10, 2014
When u put some magnetic thing infront of your tube, colour will change like rainbow. for solution, do the same thing like hold the magnet then clear the rainbow. etc not to close then throw it outside ur panel
Posted on May 24, 2012
  • 44 Answers
Either something wrong with the picture tube or something with scart input if you use one. / / David
Posted on Jul 29, 2009
Problem with JVC CRT TV (slim) with screen to have red color at the lower left (facing the TV) corner and a green color on the upper right corner of the screen. Sometimes while watching TV shows, the upper...
There is strong magnetic field around the TV. This may be due to the tower speakers or any portable radio kept close by.
Re orient the TV try switching OFF / ON at the intervals of 30 minutes. The built in auto de-gauser will correct the problem. In cable TV program if the picture is OK, nothing wrong in the TV.
Check with a different CD.
May 19, 2010 | JVC AV-21QMG3 21" TV
I am starting to get a discoloration in the bottom left side of my screen. It is slowly making it's way up to the middle of the screen.
If it is a tube type TV, probably needs degaussing. The screen within the crt becomes magnetized or external magnets from speakers are causing a problem. Sometimes changing the direction or position the tv faces causes degauss problems. If moving nearby speakers changes the discoloration, then speakers are too close or TV needs degaussing. Some high-end Asian tvs have E-W adjustment in users menu to correct this problem.
If it is RPTV 3 tube crt TV, maybe a convergence problem.
If it is DLP or LCD rear projection, probably optical engine failure.
What model is TV. Is picture normal in BW with color turned off?
easyab
Apr 22, 2010 | Televison & Video
TV KOLIN 21"
hello.... do you have any speakers near your television? what color is the circle your talking about? Do the green,pink colors are scattered all over the screen and specially on the corners?
If you have or had speakers near your tv? then do this try to get a magnet.a magnet on a speaker would do.what you have to do is to place the magnet near the screen of the tv approx. above the green,pink color (turn it on first).you will notice the that the color will react with the magnet try to pull it on the side you will notice that the green,pink color is moving on the same direction do it until its gone.NOTE make sure youll not scratch the screen ok.email me what happened. jaredreyesbalderama@yahoo.com GOODLUCK
Jan 21, 2009 | RCA 20F512T 20" TV
My tv has a pink blob in the centre with a blue large ring around
Either someone got too close to it with a magnet or you have an output problem.
Jan 18, 2009 | Panasonic PT-44LCX65 Television
TV colors distorted
make a degosing coil or try to look for a website how to make it in the phillipine we only make it coz we can't buy or its not available in the marker ok thanks that is the only solution you can do k
about akai tv may be it just coldsolder in crt socket try to solder it thanks inform me
Sep 10, 2008 | Televison & Video
Green corner of the tv screen
Do you and/or did you have a speaker or magnetic thing next to or on top of your TV? The electron beam inside the picture is steered magneticly so if it gets magnetized they land on the wrong color. The device to fix that is a 'Degaussing Coil', most TV repairmen have one. Another trick I used to do if I was on a call and didn't bring the thing was use a strong magnet near the offending color. Bring it slowly near the face of the picture and flip and turn it as neccesary to 'reverse the magnetism'. It may take some practice to get good at it. It's not permanent, worst case: get a degausing coil.
Feb 02, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Tv
you should take it to a TV repair place, they charge $50 to look it over.
Dec 17, 2007 | Sony KV-35S40 TV
Screen Colours incorrect
Your CRT (Picture Tube) screen mask has become magnetized. You need to degauss the CRT. Have you moved you TV lately or at any point had speaker sitting next to it? These are two things that can magnetize the screen mask. Well in any event you will need what is called a degaussing coil to demagnetize the CRT.
Here is the degaussing procedure:
Standing about 10 feet from the TV Screen turn on the degaussing coil which is in a vertical position and rotate it in a circular motion walking towards the TV .
Once about .5 to 1 inch from the TV continue to rotate the degaussing coil and the move away from the TV while still rotating the coil.
Once at the point where you began, position  the coil to a horizontal plane and quickly move the coil back about two feet and the turn the coil off.
This will deguass the CRT.
Thank you,
Shuttle83
Oct 30, 2007 | Sony KV-36FS16 36" TV
No blue screen
what you are describing is a degaussing problem. It normally occurs if some Magnetic source has been brought close to your TV. Perhaps you have shifted your TV from part of the room to another? Or to another room? Did you or someone place a magnetic source (Speakers, Tape recorder, Walkie talkie, some toy of your children, etc near or on top of the TV? Just remove it. And wait for a few days. The problem will get automatically cleared up, as the TV set's Auto Degaussing circuits will clear the color patches.
Aug 18, 2007 | Samsung TSL2795HF 27" TV
Color gone
you must have placed speakers around your tv. your tv tube has gotten magnetized.you will need a degaussing coil to remove those color stains if you do not have a coil call a tech to remove it for you.good luck.
Apr 23, 2007 | Samsung TXN2726 27" TV
Samsung TXN3271HF 32" TV Logo
496 people viewed this question
Henry  Thomas
Henry Thomas
