Help i can't wash and have no manual and have a hairdressers shop
We had a problem with it 2 days ago when hubby tried to do a wash. We pressed power and then within 15 sec an code message comes on display PE and ding dong ding dong noises (as if left lid up). I tried it the day after just to see and it worked then today Steve went to do a load and i did try also after him and the same thing is happening. It is as if the machine is half way through a cycle when u turn power on and then it stops. Please any answers would be appreciated. Cheers Vikki LG (Turbodrum 4.5kg top loader)
  • 249 Answers
Re: Help i can't wash and have no manual and have a...
The switch is faulty that is supposed to engage when lid is closed .replace switch under lid.close Ireland bye bye
Posted on Nov 24, 2007
0 characters
3 Points
We are at our wits end. See details. What else can we do? LG Tromm 2277 Washer no power.
either of 2 things I can suggest . 1 would be call the repair man or 2 buy a new one .
Oct 05, 2014 | Washing Machines
Washing machine plugged in but no lights on the front when I select the programme.
If there is no power at all to the panel or board then it is possible that there is some damage to the main controller board and circuit. it can be fault within the board, could be the power supply section -DC side - or there is fault in the processor or memory.
In both cases you need to remove the front panel to confirm by measuring the voltage present.
Jan 25, 2013 | Washing Machines
I cant seem to get my GEwasher to completly drain. is it possibly the drain pump? I have leveled the floor, cleaned out the hoses and it still leaves about a gallon of water in the tub, and it smells after...
Hi I just went through this with the same brand of washer like 2 hour ago!!! I found a big clog in the drain pump that would not allow the water to drain.Disconnect your hoses and clean the opening of the drain hose! I am so proud of hubby could not figure this out....good luck!
Apr 02, 2010 | GE WBSR3140DW Top Load Washer
Kenmore Elite HE5t Power and Errors
try hitting pause/cancel twice to clear the codes
May 17, 2008 | Kenmore Elite 45986 Front Load Washer
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Washing Machines Logo
153 people viewed this question
Top Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
