Question about Canon Office Equipment & Supplies
Hi my mp530 printer, has a barcode like pattern
Hi my mp530 printer, has a barcode like pattern that leaves strips of clear unprinted stripes just like a barcode. It scans ok, fax receive or copy modes,is as described pictures or text are similarily affected.
I have done the deep clean, align heads, rollers top and bottom, in fact all of the choices available. Still have the issue.
Any suggestions?
Thanks Sam.
  • samtomarchio Jul 29, 2009
    Ginko, I still have the problem, apologies if I have
    dented your pride you may be correct as I do not have a second computer to try.
    Nor a new board or the skills to install.
    Appreciate your input and trust my response can be ammended, this is my first outing on these community
    support sites.
    Thanks Sam.
  • Canon Master
  • 19,396 Answers
Try removing the printer from installed printers in Windows, and reinstalling the driver.Also test a different USB cable.
If the problem persists, test the printer on a different computer, if it still does the ssame, then the printer has a faulty logic board.
Posted on Jul 29, 2009
  • Ginko
    Ginko Jul 29, 2009
    Dear Sam,
    I will be grateful if you can change the negative rating given for my
    free advice. It is not true that the comment had nothing to do with
    your problem.
    Thanks.
    G.
  • Ginko
    Ginko Jul 29, 2009
    It is not a matter of pride , you just stated that you do not have the possibility of testing the printer, then voted my comment has something that "does not help and has nothing to do with the problem.
    All you can do in your case is :
    Reinstalling drivers to exclude software problems (does not look software)
    Cleaning the encoder strip, the encoder strip determines the position of the carriage, and can cause the carriage slipping and causing the problem.
    Use a different USB cable to test, just in case.
    If that does not fix the problem, then you need a repair shop.
    I think my answers are well related to your problem.
    Best regards.
The long clear stripe in my lexmark x4270 came out. i need to know how to put it back in
This article in the Lexmark website has some visual aids that can better guide you on how to reseat the encoder strip (long clear stripe) in your printer: Printer Cartridge Stalls or Is Blocked.
May 15, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do you clean HP print heads
  1. Cleaning a printer's printheads is an easy process. Here's how it works (in Windows). Click the Start button (or in Vista the Windows icon) at the lower left corner of your screen.
  2. Click on Control Panel. Next, choose Printers and Other Hardware, and then View Installed Printers or Fax Printers.
  3. When the Printer page opens, right click on your printer's name, and choose Printing Preferences.
  4. For the Pixma MP530, the Printing Preferences has five tabs across the top; choose Maintenance. Again, most printers should have a very similar set of options.
  5. The first button is for cleaning the printheads. You'll have to choose which printheads you want to clean (the Pixma inkjet has five cartridges). The best bet is to choose All Colors.
  6. Make sure the printer is turned on and that there's some paper loaded, then click on Execute.
  7. The printer will print out a pattern with a grid along the top and six bars of different colors. Two images will display on your monitor that you can compare to the printed image. In one, the grid and colors are sharp and clear; in the other, some of the grid boxes are missing and the colors are striped.
  8. If the printout matches the sharp, clear image, simply click Exit and you're done.
  9. If the printout has missing grid boxes or stripes, then click Cleaning. Once that's done, you'll repeat the whole process so you can ensure the cleaning was completely successful. It may take two cleanings if your printheads are really clogged.
  10. If, after two cleanings, you're still getting a poor result, there's a Deep Cleaning option on the Maintenance tab that should do the job.
Oct 03, 2010 | Computers & Internet
Zebra stripe wont print properly
Check the printhead pressure. there is an adjustment screw that does this. It could also be that your platen roller is worn or that your printhead has burned out pixels.
Dec 30, 2009 | Zebra Stripe S600 Thermal Label Printer
Hi My problem is that this plastic strip has come off of something and now the ink cartridges go back and forth really hard but doesn't print anything. There are little slits on each end of the strip. One...
Hi Debbie,
If the plastic strip is about 10mm (or ~0.4 inches) and about the with of the printer, and if you look very closely the strip is striped (with tiny very think vertical lines).. .that strip is the locator strip… The ink cartridges read that strip to know where the carriage is (ie the carriage reads/counts the strips and then it knows where it is)
Hence if the stripe is now in your possession the printer doesn’t know where the cartridges are and just keeps moving them back and fro hoping to “find them”.. sadly without that stripe you printer will work no more L
Sorry.
Ed
Nov 08, 2009 | HP DeskJet F380 All-In-One Printer
Check Printer 5100 Notification
5100 says the carriage is not moving back and forth correctly, look for any paper scraps left in the way, clean the encoder strip, the clear strip behind the carriage, sometimes grease gets on that part and gives the error. You can clean it with a damp Q-tip
Jul 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I keep getting an error message on my printer for a CARRIAGE JAM. THe message says to open door, clear carriage jam and press OK to continue. I've followed the HP steps and no luck. Can anyone help?
Hi and welcome to FixYa,
If you have verified that there is no obstruction, nothing preventing the carriage from moving, then most likely fault is dirt, ink smudge or bits of paper on the encoder strip. The encoder strip would be the narrow long plastic strip with barcode like markings. These has to be clear in between markings as they serve as guide for the carriage to tell the printer where the print head is. Cleaning could be done with a soft cotton cloth that leaves no lint.
Good luck and thank you for using FixYa.
Feb 24, 2009 | HP Photosmart C6100 All-In-One Printer
Unprinted stripes on sheets
could be the drum causing the issue or the scanner assembly.
Jan 16, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Installed all new ink cartridges and now poor printing results
Dear louis,
You have done right thing by cleaning the print head. If the print head still clogged after repeatedly cleaning, It seems that the print head need to be replace with new one. Make it sure by printing nozzle check pattern. Is it good or not?.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 28, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Printing problems
According to the manual, "If there are white vertical lines on your printout, you will need to clean the print head."
I had that problem and cleaning the print head solved it.
Mar 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
70 people viewed this question
old marine
old marine
