Question about APC Back-UPS RS Battery Backup (apw br1500) UPS System
How do I open the cabinet of my RS 1000 UPS?
How do I open the cabinet of my APC RS 1000 UPS? I'm afraid that I might snap a plastic stay if I try to force it open. Is there a technique to this?
  • 35 Answers
Plese see the manual.Remove the back side screw of ups.
Posted on Jul 29, 2009
Apc ups rs 1000 overload
Try reducing the load. e.g connect monitor to wall directly.
If overload light is persistent, UPS must be scrapped.
Jun 05, 2014 | APC (C73351) UPS System
APC RS 1500 82v output
Many UPS Systems have a squared wave when working on batteries. Cheap multimeters do not give the correct measure on squared waves. Connect a 100 watts resistive lamp to the output of the UPS, if the light is almost the same when UPS is working on batteries, everythinf is fine.
Dec 23, 2013 | APC BX 1500 Back-UPS XS 1500 (APNBX1500)...
Having UPS Model No. BR 1500 in time of opening UPS shows over lode without giving any lode. Battery is new . can you tell me the solution.
Try to reduce your load. in a overload condition the UPS can not tell you what the load is if it has more then the 1500VA your UPS can not put out more then 1000 watts. Battery has nothing to do with the load.
Sep 09, 2011 | APC Back-UPS RS BR1500-IN (BR1500-IN) UPS...
My ups 1000 watts suddenly get off for few minutes than again starts itself .it happens 2-3 times in 24 hours.
Back up devices on the computer creates copies of every new features that are performed. The backup devices default settings may allow to save data every often like 2-3 times in 24 hours. also, the backup devices save settings can be altered to suit user speciifcations. for example, important projects on important files may require to save every few seconds lest any malfuntion that occurs to the computer is misplaced. back devices are considered external structures and should be locate on the computer systems control panel area with a unique description. Clicking on the backup devices logos would allow to manipulate either create urgent backup or space the backup to make the computer faster where back becomes attainabel durign idle hours.( for example, set the computer backup to first tthing in the morning or last at close of computer usage.)
Feb 05, 2011 | APC Back-UPS RS 1000VA UPS System
My APC RS 900 UPS is making a beeping noise and the red light on the front is blinking. It seems to be working, but what is it trying to tell me?
Without knowing which light is flashing I can only guess. From my experience and assuming it is the battery light that is lit and NOT the overload light, it can be one of two things, one is your battery is near the end of its life and needs to be replaced, and the other is that your battery is improperly connected.
To confirm if your battery needs to be replaced or not, you can run a self test. Ensure that the battery has had time to fully charge (and that it is definitely correctly connected), and then turn off the UPS, and turn it back on. It will automatically run a self test.
if the light stays lit, you need to order new batteries. One source is here: http://www.refurbups.com/APC-Back-UPS-RS-900-BR900-Replacement-Batteries
If it IS the overload light that is lit, you simply have too much equipment attached to the UPS, more than the inverter can handle. Try removing some equipment until it turns off.
Mar 18, 2010 | APC Computers & Internet
Remove battery on apc battery back ups rs 1500
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Slide the battery compartment cover off (front bottom cover).
Pull the battery connector connecting the battery to the UPS
Grasp the top and gently pull the battery out of the UPS.
Oct 08, 2009 | APC Back-UPS RS Battery Backup (apw...
No output
bacause is overloaded. There is a reset switch inside the ups, locate that and reset it.
Jul 26, 2009 | APC Smart-UPS 1000XLI (SUA1000XLI) UPS...
Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Jun 11, 2009 | APC (br800) UPS System
APC Back-UPS RS Battery Backup (apw br1500) UPS System Logo
302 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
