Question about Nokia N95 Cellular Phone
There is no light in screen also in the selection keys but screen is working good back light is not working
Black screen
Master reset with hardware keys A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloaded content, ringtones, images, apps, and contacts. It does not delete data stored on the SIM card or SD card.
If the device menus are frozen or unresponsive, you can master reset using hardware keys. To perform a master reset, follow these steps:
  1. Back up all data on the internal memory. You won't be able to since there is no display.
  2. Turn off the phone.
  3. Press and hold the Power and Volume Up keys simultaneously.
  4. Continue to hold the keys past the T-Mobile splash screen.
  5. Release all keys when the Android system recovery screen appears.
  6. Press the Volume Down key to highlight 'wipe data/factory reset.'
  7. Press the Power key to select.
  8. Press the Volume Down key to highlight 'Yes -- delete all user data.'
  9. Press the Power key to select. The unpacking Android screen appears, and once complete with the reset, the Android system recovery screen reappears.
  10. Press the Volume Down key to highlight 'reboot system now.'
  11. Press the Power key to select. The phone will automatically restart.
Mar 13, 2014 | T-Mobile Prepaid Prism II
How to fit buttons with the software
In order to associate a hardware button with a specific application on the phone, follow the following steps:
1. Go to Tools --> Settings --> General --> Personalisation --> Home Screen --> one-touch keys
2. select the key that you wish to assign an application to, from the four optional keys
3. Select "short press"
4. select the desired application from the list
5. Select OK
6. go back to the home screen.
Good luck :)
Feb 09, 2011 | Nokia E71 Smartphone
How to install change first boot divice on ibm thinkcentre computer
You must enter the "BIOS" at start up (sometimes called SetUp). Press F2 or F8 or F11 or other function key that will be required by your computer. Should tell you at boot.
Enter the BIOS settings, find the boot sequence and edit it. remember to save your changes.
BE VERY CAREFUL WHAT YOU SELECT!
Thanks for your visit today.
Feb 01, 2011 | IBM ThinkCentre A50 PC Desktop
Gateway desktop wont boot up into OS XP just blinks with cursor on black screen
try this strt the pc when you see setup on screen press F8 key a few times then you will see options like safe mode and safe mode with networking and you will see an option to boot from last known good configuration use keyboard arrows to select this option your pc will reboot if this doesnt sort it the repeat these steps and on the screen select safe mode and hit enter key or return key let the files load on the screen when th pc goes into safe mode the screen will look different clik on strt then select alll programmes then select accessories then select system tools then select system restore ....select a date when your pc was last working correctly and clik next let the computer do its work when it restarts it should be working correctly (NOTE) any progrmms you downloaded from the date you selected will be eresed but not your documents or downloads like movies ...hope this helps
Dec 19, 2010 | Gateway GT4016 Desktop PC
Hp Pavilion, tx2000, Black Screen, running, lights are flashing, Nothing on monitor
as soon as you turn on the computer keep tapping the F8 key until you see a screen called advanced boot options ..using the arrow keys in the keyboard select the option last known good configuration and press enter hope this works if this doesn't work.
again go to that advance boot options screen by following the same above said procedure and this time select the option safe mode then if your computer boots up in the safe mode then try to do system restore from start button->all programs->accessories->system tools->system restore select a date at which your computer was working fine and let it do its stuff if this works your computer will boot to the home screen..
good luck
Oct 02, 2010 | Computers & Internet
Screen is black upon start up and I cant see anything. I can hear it starting up.
Press FN+F6. If the display is not back then follow the steps.
Please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. After the if you seen the screen dark then press FN+Right arrow in key board(>). When you press FN + ( < ) or ( >) key that's time its working for brightness controlling for screen. Now if all well then fine other wise please let me know .
Another suggestion is, run your Acer driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Feb 10, 2010 | Acer Aspire One Netbook 8.9" Notebook
SIR, I AM USING NOKIA 1600 MY PHONE KEYPAD
Try following steps to get your cell unlocked with out even putting password after you unlock it reser your phone:
  1. Press Right Selection Key to enter unlock screen where you are asked to put pass code.
  2. Press Left Selection Key to go back to stand by screen.
  3. Again Press and hold Right Selection key till you are prompted [Now press *].
  4. Press [*] immediately as you are prompted while releasing Right Selection Key.
Your cell is unlocked.
Dec 01, 2009 | Nokia 1600 Cellular Phone
System won't log on
try safe mode. If it works, use system restore to go back to a previous working configuration. If safe mode does not work, try the last known-good configuration. Restart the computer, then as soon as the Dell logo shows up on the screen, press the F8 key repeatedly until you enter the Advanced Options Menu. Use the arrow keys to select Last Known-Good Configuration, then press Enter.
Jan 11, 2009 | Dell Inspiron 1150 Notebook
WASTE TONER CONTAINER
The Counter for the Waste Toner has to be reset. You go into service mode by selecting Additional Function, then depress the 2 & 8 at the same time then the Additional function key once again. You should see a screen that says copier, feeder, etc. Touch " Copier " and then you should see a new menu across the top of the screen. Far right is " Counter ". Select it and then go to " MISC ", you should see Web, Waste toner, etc. Select Waste toner and select the " C ( clear ) " key and the counter should reset to all zero's.. Select the reset key a couple of times to get out of service mode. You may want to see what's all in service mode to get an idea of what's there. When replaceing time change items most likely there will be a counter to reset in the same way. Good Luck.
Sep 24, 2008 | Canon imageRUNNER 5570 Copier
Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Nokia N95 Cellular Phone Logo
67 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
