Question about Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
Modena 80e starts up itself
Every morning about 5am my boiler starts up and then shuts down @ 10 seconds in total, I have reported it to Scottish Gas but the engineers are not interested even though I have gas cover with them. I wouldn't mind if this was usual but no one seems to know.
  • bonpurple200 Aug 05, 2009
    Not sure if it has this option, but if it did you would think it would do it at other times of the day.
    It seems to stop doing it if I have my heating on the night before. Many thanks for your response
  • 4 Answers
Doe's your blr have pre heat option if so it would be normal for it to fire up then go off
Posted on Aug 04, 2009
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
I have a Protherm 80e boiler which keeps going to the F1 mode
google your boiler it comes up with a manual go to page 26 it gives you 5 reasons why it goes to f1
Aug 16, 2017 | Water Heaters
Baxi boiler 80E low pressure on boiler how to fix it?
Silver flex hose may be the (correct) filling loop. There may be a valve at each end of it, maybe just one at one end.
Open the single valve slowly and LISTEN for the sound of water entering the system, and LOOK for signs of the pressure gauge rising.
On the dual valve version open the first, then open the second slowly as above. Close both valves when pressure is adequate. Adequate is determined by the specifics of your system, but note that more pressure DOES NOT mean better showers, etc.
It should only take a few seconds to top-up, any longer indicates a significant loss of fluid from the system.
Jan 28, 2013 | Water Heaters
Boiler coming on,on its own
Sounds likely. But check the timer selector switching [on/off/24hrs] & if you have a room thermostat wired in
Jun 13, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Sime 80E friendly format boiler
Sounds like a control board or wiring to the unit has shorted out.
Apr 08, 2009 | Water Heaters
Potterton Profile 60e doesn't start first time
could be fan speed or air pressure switch-is case seal sealing properly also check grommets under boiler for blowing.
YOU CAN ONLY WORK ON BOILER IF YOU ARE GAS SAFE REGISTERED.
Apr 04, 2009 | Water Heaters
I need a protherm 80e manual, any idea where I can download one from? The baxi site does not do support manual downloads. :(
This is the manual for 80E. It isn't a manual for the 80e, it's a manual for the 80E, dunno if they are the same or not.
http://www.protherm.cz/upload/1117176168.pdf
If that's is not it, you can browse here =>
http://www.protherm.cz/component.php?cocode=download&dcid=4
Dec 30, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Boiler shuts down repeatidly
i think you will find that instead of modulating as demand requires the boiler is overheating and then re operating after the safety thermostat has operated.
i wilud put some de scaler into the main heat exchanger circuit or add it to the radiators and let it circulate for a while.
also make sure the pump is operating properly to ensure proper water flow.
Nov 17, 2008 | Water Heaters
Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat Logo
125 people viewed this question
Top Protech Systems Water Heaters Experts
paulcarew
Donni Steen
Are you a Protech Systems Water Heater Expert? Answer questions, earn points and help others
