SOURCE: computer won't boot up with disc in drive
The computer is looking for boot information on your DVD drive for some reason.
Do not boot the computer with any disc in the drive, and see what happens.
SOURCE: Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash
intermittently. While set was in this mode, could not enter menu,
change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an
overheating issue. But unplugging the Viera and waiting for set to cool
made no difference.
I then remembered that this issue popped up the instance I surfed to a
particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora,
Illinois, USA). I had a hunch that there might be an issue with the
signal on the channel that prevented the Viera from properly syncing,
so I decided to unplug the antenna cable. Once I did that, the channel info
displayed steady. I was then able to change channels (of course screen
was blank as antenna cable was unplugged) and enter the Viera menu. I
immediately went to channel set-up and manually removed channel 26-3
from the channel list. After reconnecting cable, Viera was back to
normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the
Viera remote and front panel controls inoperable. Pure speculation, but it could
be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel
controls.
SOURCE: Display says 60hz always
Ignore it. That rate (60hz) is what the cable provider is refreshing at as the signal is sent to the box, but the TV will then refresh at 120hz. I know that the manual does not state this, but the TV is working correctly. Go to the "menu" and "picture" and set it accordingly.
SOURCE: I have a toshiba dkt2010-sd how go i program this
What do you want to program? to get rid of blinking light press intercom and dial #409 to program display name type Intercom #620 and #621
