Question about Precor Exercise & Fitness
My Precor EFX 833 elliptical shuts off in the middle of use m, I’ll be in the middle of a workout program and it will turn off
    Master:
  • Precor Master
  • 165 Answers
If you are using Electrical power coming from outlet box 110vac, The Power supply inside is defective. Or if you are using batteries, has the same problem with the converter-power supply, Repair or replace.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Posted on Nov 03, 2017
5 Suggested Answers
SOURCE:
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
dcramer531
  • 1654 Answers
SOURCE: How do I replace the
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots on whom the sell parts and support to.
There is a place on line to get some of these, it is. www.treadmilldoctor.com/Products-Services2/precor-treadmill-belt.
The manual can be found at. fitness.manualsonline.com/ex/thread/view/idThread/2141832
This place has manuals and user manulas along with support and some partswww.shopwiki.com/Precor+EFX+5.171 I believe this unit has a 10 yr warranty with it and the part in question may be covered by them. There is also a 1 year part warrant for other parts, I just don't know what parts they are covering for the 10 yr.
Posted on Dec 26, 2010
ercupa190
  • 12223 Answers
SOURCE: My Proform crossover Elliptical's interface keeps shutting off in the middle of the workout. Any ideas?
Dear Sir:
Electronics in consoles can fail at any point like a light bulb. We have spikes in the power supply to our homes which can wear out components over time. If the machine shutting off is there are indication some components in the power supplies is faulty. Test and replace.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Mar 10, 2012
info95456
  • 10 Answers
SOURCE: My Precor EFX 5.17i elliptical trainer keeps displaying "Error 40" even when I turn it off and back on. How can I fix it?
This is an incline error. Check fuses and incline gear for jammed incline. Call 877-805-1030 or www.techmotionusa.com for service tech if you still need help
Posted on May 09, 2015
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
Precor efx 576i resets everytime user changes direction
Does the lift work? If not, the battery is dead. Replace it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Feb 17, 2014 | Precor Efx 576i Experience Elliptical...
I want to replace the battery
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
Feb 11, 2014 | Precor EFX 546i Elliptical Version 4
Replacing battery
Feb 07, 2014 | Precor EFX 546i Elliptical Version 4
How do I replace the battery on efx 546i
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
How do i change the battery on a precor efx 5461
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Dec 25, 2013 | Precor EFX 546i Elliptical Version 4
Service manual 546
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Please use your model and serial number to narrow down your search. In the middle of our Web page you will find the service manual for your machine.
Sep 03, 2013 | Precor EFX 546i Elliptical Version 4
Precor efx 556
Here you will find parts and other information for the Precor EFX 556.
Repair Parts for Precor EFX 556 Ellipticals SPORTSMITH net
Jan 07, 2012 | Precor EFX 546i Elliptical Version 4
My drive belt for my Precor EFX 5.33 broke. I have a replacement belt and would like detailed instructions on how to replace it.
Use this link and have your serial number ready. On the left of the screen, you will have the option to click on your serial number range. You should see a tab in the middle of the screen that shows manuals. Click on the service manual and you will have the information you're looking for.
Repair Parts for Precor 5 33 Ellipticals Consumer SPORTSMITH net
Feb 27, 2011 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
330 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Ross Metcalfe
Ross Metcalfe
Jose Pino
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
