Question about Motorola Mobility L6 Cellular Phone
LCD screen of mine mobile Motorolla L6 mobile gets damage... and even single chracter will not display on LCD screen Plz tell me how i repair the LCD screen..myself
My i-mate mobile his display not working, i want to new display set my mobile. so plz, help me,
If the display is not working you may check your Mobile LCD screen is broken or cracked and on the outside is completely intact but the inside looks like a smashed pain glass or if you can`t see anything on the screen try visiting mobile repair center. You may try this link for them to check your mobile.
http://mobile-repairs-service.com/repair/lcd-display-problems/i-mate-sp5/10/879.html
Mar 16, 2011 | i-mate JAQ Pocket PC
Pls i connected my L6 motorola phone via usb to my pc and installed the driver automatically. after the installation, it only charges my phone. tell me what i can do to acess my phone from my pc?
WHEN CONNECTED YOUR MIOBILE TO PC INSTALL MOTOROLA PHONE TOOLS... THEN FOLLOW THE INSTRUCTIONS... THEN LAUNCH MOTOROLLA PHONE TOOLS...SELECT THE MEDIUM OF YOUR CONNECTION (DATA CABLE)AND SELECT MOBILE MODEL...SELECT OK... PICTURE OF YOUR PHONE WILL APPEAR ON THE SCREEN ... NOW CAN ACCESS YOUR PHONE WHEN CONNECTED SHOWS ON THE SCREEN...
Oct 04, 2010 | Motorola Mobility L6 Cellular Phone
Dear i have same mobile.. but now a days there is problem on the front screen of mobile dat there is lining is showing.. i cant see main display properly tere is some light lines on the display.. plz ans...
check the flex/ribbon wire of the LCD may be loose or damage. but if try to use a good LCD, your LCD may be damage and need to replace with a good 1...
May 24, 2010 | Nokia 6131 Cellular Phone
My nokia model 6060 was kept in tablesuddenly fall from the table after some time when iawmy mobile everthing was ok it was working properly but the lcd light was not glowing i went to mobile repairer shop...
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is the solution! Please vote!
Feb 14, 2010 | Nokia 6060 Cellular Phone
L6 White Screen
there is the problem with your software.
install new software from motorolla repaire center.
Dec 27, 2008 | Motorola Mobility L6 Cellular Phone
Regarding Display of mobile
okay yes you do need a new display....i will see what i can do with a location for you
Oct 24, 2007 | Motorola Mobility L6 Cellular Phone
LCD problem
NOT ONLY UR LCD IS DAMAGED ,UR PBA IS ALSO DAMAGED IN ACCIDENT. SO REPLASING PBA N LCD WIL COST TOO MUCH. SO BUY ANOTHER1
Sep 18, 2007 | Motorola Mobility L6 Cellular Phone
No display but it works
I have taken the Motorola L6 apart bit by bit and reconnected it. If you open the back you will find 4 screws to undo on a silver casing. Once inside the phone you will look at the very top left where you will find a gold coloured connector with pins on the underside. This bit controls the display. If it has come off you can push it back into position with your finger. If it hasn't come off it may just be loose. Press until you feel it click into place and voila! Picture is back.
Jul 13, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
