Connect ipod to awa usb portible player
I have just bought a AWA UC1001D from Big W. The CD player and radio work but when I connect the ipod thru the USB cable it wont play. The ipod comes up with the ''eject before disconnecting'' message and wont do anything else. The AWA player just says ''no''??
I have followed directions and there is no CD in the player at the same time.
Any help greatly appreciated, thanks.
  • 3 Answers
SOURCE: car radio that has a USB connection Ipod doesnt work
This may be part of you problem........................
Hi this is the solution to the issue with the USB Error.
I recently bought one of these head units and found that when I inserted a USB it comes up with a 'USB Error'. Well I searched on Google and found others with the problem but no solutions. So I played around and here is the solution that worked for me.
Try lots of different USB Drives. Mine started to work with the forth one I tried. The size doesn't seem to be the issue as I tried a variety of sizes both small and large. But the one that works is a old one I have had lying about for ages (512mb) so it maybe USB 1 it may not be but that is my best guess.
I have been using the USB almost exclusively now without any problems.
I have yet to try the SD MMC Card so I can't comment on how that works.
Hope this helps somebody out because this seems to be so far a great little stereo, if you can find a USB drive that will work with it.
Best regards
dunncha.
Posted on Sep 21, 2008
  • 6 Answers
SOURCE: AWA set top box STB232 connected to Panasonic LCD
Loss of sound is often a SCART connection problem. Check that the SCARTS are pushed in securely. Or if the SCART is old, it may be faulty. Try a newer one, or one that you know is definitely ok.
Posted on Mar 22, 2009
VOTIT
  • 2071 Answers
SOURCE: why wont my kenwood cd player work ?
First you do is to unplug the cord of your CD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the CD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the CD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the CD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Posted on Jul 02, 2009
SOURCE: Can't play iPod movies on my JVC KW-NX7000
You will nee a KS-U20 Lead from JVC to make videos work.
Then use the AV to view them.
Posted on Jul 22, 2009
Testimonial: "Thanks much."
  • 4 Answers
SOURCE: Crosley CR704 record player wont work, HELP!!!
Sounds like one of the internal fuses opened up. Had it apart yet? :o)
Posted on Aug 02, 2009
Phillips Universal remote SRP2008b/86 will not operate my AWA DP239 DVD player even though there is an awa code listed.
Try using code search. Also, Philips may be able to provide a code as code lists are sometimes updated.
Nov 13, 2013 | Televison & Video
Awa vinyl converter to cd model 2528
http://ernie.awa.com.au/AWA---CD-Turntable/default.aspx
Jan 29, 2012 | Audio Players & Recorders
AWA DP747 Remote
1. make sure there is no disk in the player 2. plug in the usb device 3. wait (about 10 seconds) until the player detects it and comes up with the file list 4. press play button on the player 5. when the first file is loaded press "next" to go to whatever you want to watch.
Mar 29, 2010 | Televison & Video
Hello there, i bought a awa dual alarm clock radio cd player, but its not playing, i dun know whats wrong, i did not get any manual, can u help me pls...
are settings on correct position? Alarm/alarm sound/radio....am/fm .. CD slide must be on correct setting or you will only get alarm working
Mar 08, 2010 | Audio Players & Recorders
I recently purchased a DVD which is Region 1, we are Region 4 and the DVD will not play on our AWA Combination DVD/VCR. Any suggestions?
Search google for region-free/multi-region codes codes as well as your DVD Player Model
e.i.: AWA DVDS203 region free codes
e.i.: AWA DVDS203 unlock region
Replace "DVDS203" with whatever model your DVD Player is.
Do not pay for codes! The unlock method may be simply typing some stuff into your remote or having to download firmware upgrades, burn to CD and play on the DVD Player.
Warning: Unlocking DVD Players MAY void some warranties!!
Jun 06, 2009 | Televison & Video
Stylus Needle
Do a search for Crosby turntable cd recorder.... they are the same as the AWA.... and then you can find the make of needle etc.
Sadie
Jan 11, 2009 | Audio Players & Recorders
I want to connect a tiny mp3 player to one of those portable CD players with speakers (it's a cheap AWA brand) using the USB plug - but the portable won't recognise it. What am I doing wrong?
u can't connect those two because they use two different kind of digital frequencies. So don't try it! You may end up burning out One of the USB ports on the players
Aug 20, 2008 | Audio Players & Recorders
Wont turn on
press on button deeerrrrrrrrrrrrrrr
Nov 08, 2007 | Digital Audio NAP256 MP3 Player
85 people viewed this question
 Grubhead
Grubhead
