Question about Toshiba e-Studio 232 Black and White Copier
ESTUDIO 45 SPILLING DEVELOPER. BAD COPY QUALITY
  • Toshiba Master
  • 628 Answers
Since developer material is spilling, so the developer material is less, thus blur print will occur. The fastest way to solve this issue is to replace a whole new developer unit with new developer material, but this might be quite costly. Otherwise, u need to ask technician to check your machine. Then only can confirm the defects.
Posted on Jul 29, 2009
Estudio 355 developer appear on copy
Jan 04, 2015 | Office Equipment & Supplies
Ar5516 developer spilling out
hi 1 might be developer is very poor quality (generic) 2 check biasing in sharp normally it,s developer issuer and also in this model if u turn mag roller while replacing or just turn and re install in your machine will spill developer
Feb 24, 2014 | Sharp AR-M205 Copier
E studio 600 error cod f 105 how can reset
sir i have a toshbia estudio 600 the copy is coming light but i put the toner manually in the developer tank the copy is o.k. toner is full and the developer also new
Dec 01, 2013 | Toshiba E-STUDIO 650 Copier
The copy is not clear on one side
Check Developing unit if all developing gears in good shape and the amount of developer presence could be lack of developer due to developer spilling.
Feb 20, 2012 | Office Equipment & Supplies
When i do a copy that time copy was complete but copier is not ready apx after 1 minute than copier is ready. (slow the copier)
In developer unit, when you pull out the unit form the copier left side of the developer unit there is a small cover with one screw remove the cover and expand the steel connector and fit it back.the toner sensor cover.
May 02, 2011 | Toshiba Estudio 200L Copier
We are having a problems with Mp2000le,1600,1900...Toner Spilling..we replaced the whole development unit and developer.but still after a month or two with a minimal copy volume of 100 copies per day.toner...
Just to clarify... You have 3 machines with the same problem?? Or you are just saying the model segment??
Have you saw the toner supply unit?
That unit have Mylars to carry the toner to the development unit. You can open the toner supply unit and see if the Mylars are out of the place.
Mar 02, 2011 | Ricoh Office Equipment & Supplies
I have A problem of SC990 in the ricoh aficio 2035/45 and also I get light copies and over tonning problem.
The light copies and overtoning is probably caused by the developer going bad. Do you have a service contract on your copier? It's likely time for a whole PM (preventive maintenance) procedure.
The sc990 is probably caused by the copier's condition as well. Once you have the PM done (or at least replace the developer, rebuild the photoconductor unit, and clean or rebuild the transfer unit) the sc990 codes should go away along with the poor copy quality.
Jun 19, 2010 | Ricoh Aficio 1035 Copier
COPY QUALITY
Voids are most often caused by lack of sufficient developer, which needs to be changed by a technician. developer has metal beads in it to draw the toner and make a full (dense) copy or print. these beads wear out or "dump" which initially cause gritty prints, then washed out prints. hope this helps.
Jul 09, 2009 | Toshiba e-Studio 45 Black and White Copier
Toshiba e-Studio 232 Black and White Copier Logo
130 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
