Question about Nokia N95 Cellular Phone
I accidently let my phone in a small puddle
Wen i press a button instead of doing what its spose to do it does other stuff. (eg. if i dial 5, 438*# will come up)
or if i press backspace the menu will come up
    President:
  • 1,884 Answers
You should have removed the battery immediately and used your hair dryer on it to remove all traces of water that may have lodged inside. Do that now and your keypad will start working as before. But NO HEAT, we dont to toast the phone.
Posted on Jul 29, 2009
Where, on my phone, do I find how many minutes I have left?
Depends on your Service Provider and country.
Generally balance is mentioned in terms of currency instead of time or minutes
eg. For
(a) in UK Vodafone dial 2345
(a) in US T-Mobile dial #225#
(b) in Canada Wind.ca it is dial *123#
(c) in India Airtel it is dial *121*2#
Mar 31, 2016 | Alcatel Cell Phones
The ringer will not ring, everything else is perfecty fine and working well
Your phone is set too silent. If it has buttons on the side, try pressing the up arrow button until it's loud enough for you. Alternately, go into the phone's settings and look for a "Ringer Settings", "Sounds", or "Profiles" category. You should be able to adjust the volume from there.
Feb 28, 2011 | Cell Phones
Hi, the incoming message red light is staying on. However all new incoming messages have been cleared. How do I fix this ?? Thank you DOnna
2 ways to clear this (most likely someone tried to intercom you and pressed the message button on accident instead of hanging up):
way #1:
1) press the "MESSAGE" button
2) on the screen it will display who turned on your message light
3) press the "CLEAR" button (third button from the left directly under the screen)
way #2:
1) press "INTERCOM"
2) dial " *700 " then your extension number (you will hear a confirmation tone)
3) hang up
Jan 06, 2011 | Panasonic KX-T7630 Corded Phone
KX-T7730 phone. Need to reprogram one of the PF buttons as a CO2 button. I accidently messed up the programming of this button while trying to program a different PF button as a one-touch dialing...
Just so we're on the same page, the PF buttons are the 12 buttons on the right and their ONLY function is one-touch dialing. They can't be CO buttons. The 12 buttons on the left are called CO buttons and they can be programmed to do a number of things, including CO, DSS, and feature access buttons.
To reprogram the button, press PROGRAM, the button, the dial 0 + the CO number (1-8) and STORE. Extensions are 1+ext and one-touch are 2+. Other features are in the programming guide.
The PF buttons are programmed by just dialing the digits, but if it calls out, you must dial an access code first, usually "9".
Carl
Jun 17, 2009 | Panasonic KX-T7730 Corded Phone
Program and use speed dial numbers
speed dial must set at port ' 00 ' or 000
to check, use display phone, press #402 or #401
speed dial code are from 60 to 99
to set press speed dial , redial , speed dial code eg. 60, press 9 follow by destination number asn redial to confirm
to use speed dial to call press speed dial short key follow by speed dial code or *60
May 26, 2009 | Toshiba Lands Phones
Phone is displaying DND (do not disturb)
Do not pick up the receiver press feature button dial 60 press feature button again, at least this worked for me.
Mar 17, 2009 | NEC DTU-32D-2 Corded Phone
Outside Line Button.
I doubt you would be looking to "delete" the number. Instead you need to program that button to be a line button again and that will in effect delete the quick-dial you programmed. I'm not sure which phone system you have your phone connected to (you could have one of several different Panasonic systems) but programming the button for a line should be somewhat similar to programming it for speed-dial.
Does the manual you have cover any other programming options for buttons?
It's a long shot but some systems I am familiar with you can just push the same button again instead of the number. So for example if this was the line3 button, program similarly as you did before but at the step where you dialed the number, just press the line3 button.
If you're still stuck, let me know which Panasonic phone systm you have so I can look up more detail (the system is not a phone)
Feb 15, 2008 | Panasonic KX-T7730 Corded Phone
Deleted my voicemail key
Use the super key again to program a speed dial key that dials the voicemails number. Instead of selecting 'clear' slect "change" and type in the number. To find the number of the voicemail, go to another phone and press their voicemail key and watch the display. It may briefly display the voicemial group number. You also can dial the voicemail number without the use of a button on your phone. But, you have to know the voicemail group number to dail it. Sorry i dont know the number to tell you, it could be anything that the installer decided to make it.
Sep 27, 2007 | Mitel Superset 4025 Corded Phone...
LG Prada memory
No, copy your music to the memory card rather than storing it on the phone. you must do this in 'My stuff' folder, select 'sounds' select the mp3 then click the bottom left button (details), then press 'file', then 'move' To view the moved files goto 'My stuff' folder, select 'sounds' then in the top right corner you will see a picture of a memory card. press this to see swith to view the external memory.
Sep 11, 2007 | LG Prada KE850 Cellular Phone
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
Nokia N95 Cellular Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
