Hotpoint WF865 Washing Machine Generally Louder Than When New.
We have a Hotpoint WF865 Ultima 'Super Silent' washing machine. It's about 4 years old now.
When we first bought it, I remember remarking that it was quieter thank our microwave when on full spin. This is no longer the case and it is now difficult to hold a telephone conversation when you're in the same room.
There are no noticable banging, whirring or scraping noises that you might associate with items getting stuck or faulty bearings. It's just generally louder at doing the spinning.
I did wonder if there was any way or increasing the tension on the drum so that it can't wobble as much. Maybe the noise comes from excessive play on it's suspension.
Any ideas?
  • 82 Answers
The machine has 5 year garentee onit 1st year all free next 4 years parts only the bearings have gone if it soulds like a plane taking off phone hot poit for a quote first then shop around this is a very big job very hard to do unless u r trainned
Posted on Jul 29, 2009
Will this machine work with just a cold water supply
It should work with a cold water supply WF865 hotpoint if it has one connection on the back it is a cold fill machine all new machines are cold fill only hot fill has gone now. hope this helps.
Dec 27, 2010 | Hotpoint Ultima WF865 Front Load Washer
Can a HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN washing machine run off a cold fill only
The simple answer is yes, via a Y piece if it is a hot and cold fill model
The fitting is available from B&Q, or a plumbers merchants
Aug 13, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 23, 2010 | Hotpoint Ultima WF865 Front Load Washer
How do i fit a belt to hotpoint washing machine WF865
*********** unplug from mains************** top cover off ....rear cover off ....remove old belt belt ...place new belt on lower puly feed it on to larg pull turn at same time ************WATCH YOUR FINGERS ********THEY CAN GET CAUGHT EASY******* done .put covers back on ...
Dec 30, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Ultima Super Silent WF865. I'm getting error code F04 there's water in the machine and it's stopped.
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Dec 14, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Door does not lock shut but machine still works. Is it easy to repair?
Exactly the same happened to our Hotpoint FWD70. The spring that holds the door latch in place has snapped. I removed all screws out of the door to find the spring and the metal rod it hooks onto and bend another hook into it (I didn't have a replacement spring), put it back together and the door works fine, although for some reason the dishwasher tablet doesn't release now!!
May 19, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint wf865 washing machine
to take out of test mode you must turn it on while pressing the start/cancel and on buttons at the same time until dOFF appears.
Jan 18, 2009 | Hotpoint Ultima WF865 Front Load Washer
Washing Machines Logo
227 people viewed this question
Top Washing Machines Experts
