Question about Whirlpool Dishwashers
Power button will not illuminate - Whirlpool Dishwashers
  • 44 Answers
If your m/c works ok then its the led or bulb gone. just get some expert to replace it. regards.
Posted on Jul 29, 2009
How do I get my computer screen to illuminate on startup?
You have a GPU issue. The motherboard is faulty.
Oct 08, 2015 | HP Computers & Internet
Screen says initializing
You may have a faulty battery/phone. This seems to be a common problem with this type of phone. If you can take it and have them check it for SAFETY CONCERNS That would be ideal, as they can reset it for you.
Caution! This WILL erase everything on the phone. You will have to confirm you want to do this before it will complete. (This is why you backup your phone. You may wish to remove the SD card FIRST.)
1. Ensure the device is powered off.
2. Press and hold the Power button for 3 seconds then release.
3. With the LED illuminated red, press and hold the Power button+Volume down key+Camera key simultaneuously then release.
The LED illuminates approximately 20-30 seconds after releasing the power button (step 2). The 3-key combination must be pressed within the 1-2 second timeframe that the LED is illuminated.
4. Press the Power button to confirm and continue.
5. Again, press the Power button to confirm and continue.
( Allow several minutes for the factory data reset and reboot processes to complete.)
Oct 18, 2013 | Casio Cell Phones
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
I run my finger over the power button but it wont turn on.
You don't need to run your finger across it, with the red light illuminated, press and hold the power button for 3 seconds you should hear a beep then a blue/green light should illuminated. If you see no light ensue the MAIN power switch on the back is switched on.
Rylan
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
POWER SWITCH DOES NOT ILLUMINATE GPS SCREEN WITH 12VOLT PWR.
bjw122266 Have you tried holding the power button down for about 10 seconds or so?
Dec 29, 2008 | Navigon 2100 Portable GPS Receiver
IR Remote193602
i dont have a code for this brand but there is always the power scan, for dvd power scans, hold down vcr, when all buttons illuminate press 500 then pound, then hold vcr button again, when all buttons illuminate press big red power button, then press up arrow once a second until dvd player shuts off, once it shuts off press pound sign below 9,
Jul 10, 2008 | DISH Network IR Remote Control
Code Search
First try this method as it is the quickest way,
To program a component using the Automatic Code Search method, perform the following steps:
1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button.
aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s functions.
Only use the codes below if the auto code search dosen't work. Codes program a zenith tv are below
Zenith 1000, 1001, 1004, 1051, 1083, 1151, 1152,
1154, 1217
You can click the link below you will be able download the manual.
http://support.rcaaccessories.com/main.html?topicid=216&Referring%20DeviceDocID%20List%20Index=1&navtypeid=16&pagetypeid=35&prevPageIndex=13&selectedmodel=RCR450&selectedFamily=generic
Mar 15, 2008 | RCA RCR450 Remote Control
Button illumination
Check see if your illuminate wire(orange) is connected properly. If it is, you should get a high illumination when your lights are off and low illumination when lights are on.
Mar 06, 2008 | Eclipse AVN5500 Car DVD Player
Dishwashers Logo
48 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
