Question about Citizen NightHawk BJ7005-59E Wrist Watch
Hi, I have just received a Citizen Nighthawk eco-Drive and, after setting the time and pushing the crown back into the normal position, the watch has stopped functioning. I can see the second hand twitching slightly, but it is not moving. Does anyone know what this could be?
  • 2,334 Answers
This could be underpowered capacitor or jammed gear train. Try to find a solution here:
http://www.citizenwatch.com/CUK/English/detail.asp?Country=CUK&Language=English&ModelNumber=JY0000-53E
If no luck, thaen you have to visit your nearest watch repair shop and ask for help.
Rate me, please.
Posted on Jul 29, 2009
Can set time on watch eco drive
Here is a simple steps to set up the time:
Pull the crown out one notch
Turn the crown to align the mode hand at the time mode Time
Pull the crown out another notch
Turn the crown to set the 24 hour hand, hour hand and minute hand to the current time.
Return the crown to the normal position in synchronization with a telephone time signal or other time service.
For full instruction and visual about your watch kindly click on the link.
I hope this will help you resolve your issue.
thank you for choosing Fixya
Mar 05, 2011 | Citizen Eco-Drive Calibre 8700 Wrist Watch
How do change the date on my citizen divers watch
Hope this will helped you fixing the time of your Citezen divers watch. Just foolow the instruction below.
Change your Citizen watch's time zone without actually moving the clock hands. On the digital display, change the city that displays on the watch, which sets the time to the different time zone. The Citizen also has a calendar, timer, chronograph and LED lights. Since it is an Eco Drive watch, it is solar powered so you never have to replace the batteries unless its backup power source dies.
Difficulty: Easy Instructions
  1. Pull the setting knob (crown) out one "tick" for setting mode.
  2. Set the mode hand to "WT-S."
  3. Pull the crown out one more "tick."
  4. Press the top button on the right side of the watch for the city setting mode.
  5. Press the lower button on the right side to "SET" the city.
  6. Turn the crown to select a different city, which changes the time zone.
  7. Push the crown all the way back in to finish setting the time.
Thank you for using Fixya.
Feb 21, 2011 | Citizen Watches
Can,t set timeon watch
OK try and follow these steps and it may help you set the time on your Watch. Once you understand the different function buttons on the edge of the case setting the time will be an easy task.
1-Note the 2 and 4 o'clock function buttons and the crown at 3 o'clock on the case edge of the Citizen Skyhawk Eco-Drive. These buttons set all functions of the watch.
2-Set the home city digital display function at 9 o'clock by pulling the crown to the first position. Rotate the crown until the mode hand in the subdial at 6 o'clock is aligned with TME. Press the 2 o'clock button until the nearest major city where you live appears. Press the 2 and 4 o'clock buttons at the same time to find the home city in the 3 o'clock digital display window. Once the city is selected, the time is automatically set by the automatic radio reception function.
3-Pull the crown out to the first position to manually set the time. Rotate the crown until the mode hand is aligned with the CAL, TME and RX-S position under the umbrella line. Push the crown flush with the case edge. Point the watch's 9 o'clock side in the direction of the radio transmitter. For example, if you live in Los Angeles, point the watch's 9 o'clock side east towards Ft. Collins, Colo., where the transmitter is located.
4-Hold down the 4 o'clock button for two seconds until the tone sounds and the second hand stops at the RX-S position. The second hand will then move to H, M or L found at the 2 o'clock subdial. Remain holding the watch in the same position. The second hand will move from the H, M or L position with the hour and minute hands to the correct time once the radio reception is completed.
5-Press the 2 o'clock button to start the chronograph's stopwatch. Press the button a second time to stop the timer. Press the 4 o'clock button to reset the timer.
6-Pull the crown all the way out and rotate it clockwise until the correct date is selected. Push the crown flush when finished.
IF you are still not able to set the time contact your dealer or the nearest Citizen showroom.
Jan 10, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Will/could you advise me on how to reset the time on my Citizen Eco drive wr100 watch that I purchased last year. Can't find my manual. Thank yo so much.... Happy Holidays!!!
1. Pull the crown out to position 2, two clicks.
2. Press and release the lower right button.
3. Rotate the crown to adjust the minute.
4. Press and release the lower right button.
5. Rotate the crown to adjust the hour.
6. Press and release the lower right button.
7. Rotate the crown to adjust the date.
8. Press and release the lower right button.
9. Rotate the crown to adjust the current month and leap year.
10. Push the crown to position 0.
Dec 23, 2010 | Citizen Eco-Drive 180 WR100 World Timer...
Describe your Citizen Skyhawk Eco-Drive JR306059F Wrist Watch Problem: How to correct 0 position of 24 four hour hand. I think its done in conjunction with hour hand but how?
Here is how to correct the 0 Position for your watch.
While your the crown of your watch is down in the starting position , turn the crown until the mode hand (this is the circle at the bottom of the face) reaches CHR
At this time now pull out the crown until it clicks two times, two the second setting of the crown.
This will bring the watch to the 0 position correction function.
you can turn the crown clock wise to correct the hour hand.
press the a button to switch hand to second, or press again to switch to minute. Then use crown again to correct 0 position.
The hour and the 24 hour hand is in conjunction with each other.
then push down the crown all the way in and you should be all set.
Oct 18, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen eco-drive BM8084-58H: I cannot change the date/day on the watch moving the crown.
mcdevito75 here, The crown should be a 2 position crown, try this, pull out the crown as if to set the hands, rotate the hands, (adjust the time) around the dial until you have the right day, Now! push the crown in, Now! slip your finger nail just under the crown and lift the crown to it"s first notch or position, this should allow you to turn the crown and adjust the date, when at the date push the crown back in and your done.
Jun 28, 2010 | Citizen Corso Eco-Drive BM8084-58H Wrist...
Hello. I let a Citizen Black Eagle Skyhawk run completely. Even after charging it for 24 hours, the watch will not run. What is my course of action? Send it in?
After charging the Skyhawk/Black Eagle watch, you need to reset it.
Here's how to do it:
Turn the crown (knob) until it's in chronograph mode (CHR), then pull it out to TWO clicks. Push both buttons at the same time and the display should turn on. The push the crown back in to complete the reset.
If that does not work and you are 100% positive it should've charged...take it in for service. It could be a bad battery (rare).
Aug 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Second does not reset to 12
You should be able to solve this by pulling out the Crown(the one with which you set your normal clock), Pull it out in the 2nd stand.
Then by pushing the 'start/stop' button --> you change the minutes.
By pushing the 'lap/reset' button --> you change the seconds
It worked for me, took me a few minutes to figure it out, i hope this saves others the time of doing that :p
May 13, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I cannot set the date on my Citizen SkyHawk Eco-Drive
Just pull the crown out, turn it so that the bottom analog display is set on "CAL" and push crown back in. Voila!!
Mar 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
My boss has a Citizen Eco Drive Skyhawk watch . . . how in the world do you set this thing? Every time I try, the second hands goes buck-nutty and spins around the dial a million times, then goes...
good morning ! to set the Eco Drive Skyhawk citizen watch,full the crown carefully wind it slowly until you reach the correct time after that push the crown back to normal possition, if the hand is turning back to the wrong time just press the button on the up side until the turn to the correct time,thank you ! god bless !...
Aug 28, 2008 | Citizen Watches
Citizen NightHawk BJ7005-59E Wrist Watch Logo
459 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
