Question about Acer Aspire One AOA150-1570 Notebook PC
When i put my aspire one laptop on,it shows the green light without coming up and i have changed the battery as well as the power pack and itis still the same
Hi
this is my lap top
acer one aoa150
power is on but screen is black
plz cover me
thanks
Posted on Jul 30, 2009
  • 152 Answers
Its might be due to the RAM ...please try to replace the RAM ... If then not worked its your motherboard needs to be replaced ..
thank u
Posted on Jul 29, 2009
Wont turn on
On all Panasonic Toughbook Models,
if the unit will not turn on try the following:
Step 1: Unplug the unit.
Step 2: Take OUT the Battery Pack.
Step 3: Plug-in the unit.
Step 4: Turn On the unit.
The battery pack acts like a giant capacitor and can
prevent the unit to turn on, especially when the unit
was previously used on battery pack and was allowed
to fully discharge to below 5%.
When the unit is turned on WITHOUT a battery pack,
then a single Green light should show on the front
edge of the unit when the cover is open facing you.
When the unit is plugged in WITH a battery pack,
then you should see a yellow, orange or green light
which shows the battery is charging. When the unit is
turned back on, then you should see two (2) lights,
one green and the other yellow, orange or green.
If the unit is plugged back in and either with the battery
in or out you see no lights whatsoever, then chances are
that something is wrong with your AC Adapter/Power Supply.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Feb 18, 2014 | Panasonic Toughbook Computers & Internet
Acer aspire 5742 does't keep power on battery. itis shutdown imediatly.. how can to fix?
If the power adapter runs the laptop, it is likely the rechargeable battery needs to be replaced. Go to www.ebay.com Type: make and model of laptop, refine search for battery.
Jul 04, 2012 | Acer Aspire 5742 Notebook
Acer Notebook want boot up
Hook a spare monitor to the video output usually on the back, if okay! the inverter board just below the screen is most likely the problem, or the backlight behind the display. But if both show the same issue it is the video graphics card normally built into the motherboard.
Apr 26, 2012 | Acer Aspire One PC Notebook
Sir i have acer 4720Z series laptop. when I plug in the power adapter it show adapter light green. when adapter pin connect the laptop then light show blink and laptop not charging.
Your laptop battery seems to be broken.
To be a 100% sure, can the computer run on only battery?
Try to have the computer plugged in to the charger for a couple of hours without starting it.
Feb 28, 2011 | Acer Aspire 4720 Notebook
My Acer Aspire 5315-2713 will not charge the battery. The light comes on and turns off after a few seconds. Works fine plugged in without battery. Already tried new battery and same thing happened.
Hello
Remove the battery from your laptop and connect it directly to power (without the battery) to see if it comes on,if it does then your battery is bad and it should be replaced
If it doesn't power on then you should also try connecting it to power with another power cord,if it still doesn't work then the power pack has blown and the best and only solution is to have it changed by someone with a bit of expertise on power packs.
GOOD LUCK!!
Jul 26, 2010 | Acer Aspire 5315 Notebook
Power supply flashes green and no lights on laptop
Remove battery pack, press and hold power button for 5 seconds, then put battery pack back in and restart pc. This should take care of it. A bad memory stick can cause problems like this as well.
Nov 12, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 3683NWXCi With the AC power connected (charging light shows green on the Laptop) when I press the start button the HDD light comes on for a second & then switches off. doesn't power on. Was...
You could have a defective battery. Do you have a spare you can put in your laptop? Also, try plugging your charger into a different power source and see if it charges properly.
Aug 29, 2009 | Acer Computers & Internet
Dell latitude d600 will not turn on / power on
it means not charging the battery pack, did you check the dc jack connector, or the.
charger check it if working properly, if the same problem open the laptop then check the baord
thanks
Jul 12, 2009 | Dell Latitude D600 Notebook
My toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Mar 19, 2009 | Toshiba Satellite 2455-S305 Notebook
Open Questions:
See all Acer Aspire One AOA150-1570 Notebook PC Questions
Acer Aspire One AOA150-1570 Notebook PC Logo
109 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
