Question about Motorola Metra Volvo Antenna Adapter (40 Vl10)
Srs airbag warning light has come on .147000 on the odo
  • 78 Answers
Hey,
take a look at www.airbagmodul.com
They're working in Airbag-Simulators and Occupancy Sensor-Simulators.
Regards
Gerrit
Posted on Aug 17, 2010
My airbag light on the driver side goes off and on and chimes every few seconds on my 2007 Pt Cruiser. I'm afraid if I drive it with this happening my airbag will deploy on me.
The warning light means that a fault has occurred in the Airbag system (known as the "SRS" system), when this light is on the SRS system is disabled, so no the Airbag can't go off because the controller module has turned it off completely. Get it fixed ASAP because right now if you have an accident your SRS system will not work (Airbags will not deploy) to save you from injury.
Jul 15, 2016 | Cars & Trucks
How do i reset Air bag code for 2006 mercedes E350
Mercedes SRS Airbag Light MOT FAIL How To Fix - YouTube
? 3:48
https://www.youtube.com/watch?v=JVEuOzYaH1M
Oct 1, 2013 - Uploaded by OBD Diagnostics
Mercedes SRS Airbag Light MOT FAIL How To Fix ... SRS LightReset (cheap, easy) - Duration: 3:07. ... Autel AL619 Clear SRSAirbag Light Mercedes W211 E Class ... OBD2 Fault CodeDiagnostic Scanner/Readers @ Diagnostic World ... 2000Mercedes-Benz CLK-Class Start Up -- SRS Airbag Light On ...
Mercedes E W211 SRS Airbag Warning Light - How to turn it ...
? 1:00
https://www.youtube.com/watch?v=KZWAPGmf-Pk
Feb 12, 2013 - Uploaded by DominatorParts
Mercedes E W211 SRS Airbag Warning Light - How to turn it off ... AUX USB Ipod iPhone adapter E-Class 2003-2008 Mercedes Benz Dension ...
How To Reset The ESP Light On A Mercedes Benz
www.mademan.com/mm/how-reset-esp-light-mercedes-benz.html
Jul 11, 2010 - They will check to see if your Mercedes Benz shoots out any codes. They will check .... How To Reset Airbag Light On A Dodge. Need to know ...
Best tool to reset SRS light - MBWorld.org Forums
Jan 14, 2016 | Cars & Trucks
The airbag warning light flashes
First check the airbag or SRS fuse if blown replace if not you will need to take the vehicle in to either the dealer or a shop that has the appropriate SRS diagnostic equipment. When the airbag light is on or flashing it indicates the SRS system is disabled and major fault is present. There are many causes from component failure due to age or accident, to a blown fuse. Check your owners maual for the location of the fuse.
Sep 05, 2011 | 1993 Ford Econoline
Warning light "ON" -airbag. How
how to reset SRS airbag light turn off the srs .
you can go here.
Aug 02, 2011 | Ford Escort Cars & Trucks
What is the SRS warning light for and what does it mean
SRS stands for Supplemetal Restraint System. It is your airbags. If the warning light has come on that means your Airbag system has a fault. It is never recommended for you to do your own air bag work unless you have the proper training. It is a life saving device and needs to be taken care of properly and promptly.
Dec 08, 2010 | Volvo 850 Cars & Trucks
SRS connector airbag warning light is always on?what should i do about it and how can i fix it myself if possible?
Remove the negative battery cable for about 25 seconds to see if it will reset,if it does not,then the air bag module is bad,Rate if this was at all helpful,thank you.
Jul 18, 2010 | 1993 Toyota Corolla
What is the dash light srs, in a honda accord 2002 vtec engine 3.0
The SRS, or supplemental restraint system, on your Hondamag-glass_10x10.gif Accord 2002,
Read more: How to Reset a Honda Accord SRS Light | eHow.com http://www.ehow.com/how_6403892_reset-honda-accord-srs-light.html#ixzz0tQdveFZn
responsible for deploying the airbag in the event of an accident. If this system is malfunctioning, the airbag may not deploy properly during an accident. However, the system does warn you of a system malfunction. The yellow "SRS" light on the dash will light up, indicating a problem with the system. Once you've fixed the problem, you need to know how to reset the SRS light on your Accord
Read more: How to Reset a Honda Accord SRS Light | eHow.com http://www.ehow.com/how_6403892_reset-honda-accord-srs-light.html#ixzz0tQdgZ0ic
Jul 12, 2010 | 2002 Honda Accord
SRS airbag light flashes 4 times and then stays on
u have to diagnose it to know the fault .
WARNING the airbag system doesn't work when SRS illuminates
Sep 15, 2009 | Pontiac Grand Prix Cars & Trucks
I have a 2001 hyundai elantra and the warning lights on the dashboard. I know what the oil light looks like and the airbags. What are the other two lights.
Your best bet is to go HERE and signup for a free account then Downloading your Manual - service sheets, diagrams, parts lists etc.
Hyundai is one of the best with providing their customers with free information about the vehicles!!
I have D/L the manual, and the warning lamps on the instrument cluster are...
Left to right...(starting under temp. Gauge)
WITHOUT TRIP COMPUTER
11. Traction Control Indicator Light (If installed)
12. ABS Warning Light (If installed)
13. Seat Belt Warning Light
14. Oil Pressure Warning Light
15. Charging System Warning Light
16. Parking Brake/Brake Fluid Level Warning
Light
17. Malfunction Indicator Light (MIL)
18. SRS (Airbag) Warning Light
19. Trip Odometer/Odometer
20. Trip Odometer Reset Knob
21. Low Fuel Warning Light
WITH TRIP COMPUTER
7. Front Fog Indicator Light (If installed)
8. Door Ajar Warning Light
9. Trunk Lid Open Warning Light
10. Parking Brake/Brake Fluid Level Warning
Light
11. Malfunction Indicator Light (MIL)
12. Charging System Warning Light
13. Oil Pressure Warning Light
14. SRS (Airbag) Warning Light
15. Cruise Indicator Light (If installed)
16. Seat Belt Warning Light
17. ABS Warning Light (If installed)
18. Traction Control Indicator Light (If installed)
19. Automatic Transaxle Position Indicator Light
(Auto T/A only)
22. Low Fuel Warning Light
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 21, 2009 | 2001 Hyundai Elantra
Motorola Metra Volvo Antenna Adapter (40 Vl10) Logo
347 people viewed this question
Top Motorola Electronics - Others Experts
Are you a Motorola Electronics - Other Expert? Answer questions, earn points and help others
