Question about NEC-Mitsubishi MultiSync LCD2170NX (Black) (Black, Light Grey, Silver) 21.3" LCD Monitor
ON /OFF SWITCH BROKEN - NEC-Mitsubishi MultiSync LCD2170NX (Black) (Black, Light Grey, Silver) 21.3" LCD Monitor
    Problem Solver:
  • 5 Answers
Better that you bring the unit for repair, to check and possible fix of the monitor.
Replacement on the switch I think has to made, to put back into normal.
For any other related concerns, let me know
Posted on Jul 29, 2009
Thanks.. I have a onan 7500k living in from the storm. Will not start with remote inside switch. But you can shut it off with inside switch. Outside switch works great.
Need more info.
Inside does it have an 'on/start' switch and a separate 'off' switch ?
If it does -
1) the start switch is bad.
2) could be a broken/loose/corroded wire at the start switch 3) broken/cut wire to the Onan
4) broken/loose/corroded wire at the Onan where the inside start switch connects.
The fact that it starts at the Onan tells you it's OK.
Sep 17, 2017 | Electrical Supplies
Sole F85 Hand Rail Incline Adjustment Switch is not working
The hand rail switch contacts can be worn out. The more likely problem is a broken wire by the arm. Remove the cosmetic covers by the hand rails and check for broken wire. If wires are not broken replace the switch.
Aug 12, 2013 | Sole Fitness Sole F85 Treadmill
Ge electric dryer dpsr483ea1ww, dryer stops when start switch is released
Broken belt or broken belt switch or broken wire or bad motor.
Sep 05, 2012 | GE Dryers
Broken switch for cd/tape/radio
Hi. If the switch is not mechanically broken, the problem is to be found in oxydation from the contacts. A treatment with contact-cleaner mostly cures the problem.
Jul 01, 2012 | Durabrand Audio Players & Recorders
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
Samsung notebook N150 on/off switch broken
One of two things is broken. 1) the rear fork of the plastic switch is suseptable to bending a breakage. 2) The springloaded switch whick is soldered to the base circuitboard could also be broken.
Jun 05, 2011 | Samsung Tablets & eReaders
Broken ignition switch in 1986 m/b 560sel Have
you will have to replace the lock barrel(not cheap)
Apr 06, 2010 | 1991 Mercedes-Benz 560
Wireless switch is broken on my acer aspire 3680.
No you need switch,if you use a tiny screw driver you can turn it on with that if its just the plastic peice thats broke.use the screw driver to slide the mechanisam
Oct 04, 2009 | Acer Aspire 3680 Laptop
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
Broken on/off switch
need to replace the on/off switch for this camera. I have the broken piece that cannot be repaired. How can i find a replacement switch. I can repair the camera myself with the new switch. thanks.
Jul 19, 2008 | HP Photosmart M425 Digital Camera
NEC-Mitsubishi MultiSync LCD2170NX (Black) (Black, Light Grey, Silver) 21.3" LCD Monitor Logo
51 people viewed this question
Top NEC-Mitsubishi Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
mukhtar21 shaikh
mukhtar21 shaikh
Are you a NEC-Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
