Question about Coleman Refrigerators
We have a Porkka cold room. Wonder if anybody knows where i get a manual to clean the fan by myself. (We need to get a mechanic every 3 months cause the fridge goes done due to dust)
SOURCE: ge side by side not cold enough in fridge or freezer
the fan behind the freezer panel inside
Posted on May 31, 2008
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
eagle338
  • 4889 Answers
SOURCE: Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Posted on Sep 27, 2008
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: The freezer is cold but the fridge is 70 degrees.
If the freezer is good and does not have frost building on the rear wall the electric controled damper between the freezer may be frosted shut or defective. Part Number 67003903. Check that first Sea Breeze
Posted on Oct 22, 2009
Testimonial: "Ok. I set the temperature on the fridge at its lowest and the damper closed raised temp and damper opened. "
2008 Ford Focus a/c cleaned & recharged, why is there no cold air?
Could be gas has leaked out causing low pressure and no cold air!
Dec 28, 2015 | 2008 Ford Focus SE Sedan
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
PTAC unit fans working but not circulating cold air
switch off the unit, manually open the vents and check how dirty the fan blades are. Clean if required. if clean check gas level ,the fan speed is deturminded by the gas
Jul 14, 2013 | Heating & Cooling
Need a repair shop in the baltimore area to look at my dehumidifier runs but wont pull water
It's cold outside. If the temperature is too low, the cold coils will just frost up and you won't get much water 'pulled'.
Check to see if the cold coils actually are getting cold when the unit is running and the control is set to cause the compressor to work-not just the fan.
If the coils are cold and full of frost or ice, the room is too cold for the dehumidifier to work. You'll have to raise the temperature of the room or wait for warmer weather.
If the coils never get cold, the compressor might be bad or the unit might have lost its freon.
I wonder, though, if it's just too cool and dry right now for a dehumidifier to be pulling more moisture out of the air.
Hope this helps!
Jan 01, 2011 | Haier Dehumidifiers
I have 2003 Passat with 140K on the clock, 8 months ago it developed a screeching noise turning the wheel left and right when stationary like the belt was screeching. The garage could not see a problem,...
the screeching noise could be rubber deposits on the belt pulley or pulley bearings for the power steering pump BUT its also a big clue that the timing belt tensioner is about to give up...CHECK BOTH please.....
Oct 13, 2010 | 2003 Volkswagen Passat
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
The best thing for you to do is to call Mitsubishi Tech. Support directly..they are first class and will probably know exactly what the issue is...
For technical application questions, please call:
Mr. Slim: 1-800-433-4822 (press option #3).
heatman101
Aug 26, 2010 | Mitsubishi Heating & Cooling
My KOLIN window type remote control AIRCON is building up ICE
If you already had the coils and filter cleaned and the blower is OK, that only leaves the refrigerant charge.
You are probably low on refrigerant.
Jul 26, 2009 | Heating & Cooling
Need to know if indoor unit fan shuts off at desired temperature
Check your operating instructions and see if indoor fan unit has an "auto" feature that allows the fan to run only when the outdoor unit is running. Allowing the indoor fan to run constantly will provide for better air circulation and less stagnation but will use more energy.
May 10, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
2002 Grand AM GT turning over, but not starting. A/C blows fuse.
A/c Compressor Locking up Drawing too many amps and popping fuses.. Check Compressor.. Thanks.. Lemmie know
Mar 17, 2009 | 2003 Pontiac Grand Am
Refrigerators Logo
122 people viewed this question
Top Coleman Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Coleman Refrigerator Expert? Answer questions, earn points and help others
