Question about Texas Instruments Office Equipment & Supplies
I wana make a graph link cable and need to know how to wire it.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Take a look at http://www.ticalc.org/hardware/cables/
Posted on Jan 22, 2010
Cd player color code wiring panasonic cq
FYI if you remove the factory unit it will disable the cars starter and or fuel pump. The radio is tied into the security system. You shoud be able to get the wiring color codes here:
Jan 17, 2014 | Oldsmobile Cars & Trucks
What is this card in my GT5694 in the PCI Express slot?
Sounds like a LAN card, you know internet, should have a port that looks like a phone line or RJ-45, which is a cable line for internet.
Onboard and cards for a LAN, have these lights, the link is for internet activity.
There is nothing needed in a PCI slot to run a PC, the only thing would be a graph card, and that is easy to tell because it has a graph plug or your monitor is plugged into it. A VGA port.
Besides this, no. But it is not slowing down the PC, or hurting anything.
Do not touch it or remove it unless you power down, unplug the power, hit the power button twice and make sure the PC lights don't flash.
Then touch metal just before you try and remove the card.
Mar 31, 2013 | Gateway GT5694 Desktop Computer
How to download the Texas Instruments TI-83 Plus Calculator
1.Get linking software for your computer, such as TiLP, or TI Graph-Link, and follow the installation instructions to install it.
2.Plug your cable into the computer (where depends on what cable you have)(somtimes your computer does not have the right kind of entrance) and the other end into the calculator.
3.Start the linking program that you just installed. If it detects the calculator, everything is working fine, and proceed.
4.Download calculator software from the internet. You can find many programs athttp://www.ticalc.org
5.Make sure downloaded program is unzipped and located in a normal windows folder
6.Select the program you downloaded in your linking program (how you do this varies between programs) and send it to the calculator. For Windows this can involve finding the unzipped program in windows explorer and right clicking it (from a normal--nonzipped--folder window) and selecting "send to TI device"
7.Use the program on your calculator.
TIPS: If you have a USB cable, you will need either TiLP or TI Connect, no other software supports it
Things you'll need:
-A Texas Instruments graphing calculator
-A link cable for the calculator
-An internet connection
Aug 18, 2011 | Texas Instruments TI-83 Plus Calculator
How to use graphing calculator?
The casio FX-300Ms calculator cannot do graphs. To tell you how to use a graphing calculator TO DRAW GRAPHS we need to know the exact brand and model number of the calculator.
  1. Most graphing calculators basically function the same way.
  2. You select the graph type (function, polar,parametric, sequence, 3D, wire mesh, slope field, etc.)
  3. You enter the algebraic form of the function you want to draw.
  4. You press a button or menu to GRAPH
  5. The graph is drawn.
  6. If you want to see a particular part of the graph, you use a ZOOM function, or you enter values for the WINDOW dimensions.
  7. Most graphing calculators have a TRACE function that allow you to follow the curve you have drawn to read off values of coordinate points.
  8. You can also use the calculator to find zeros roots) of functions, calculate derivatives at some chosen points or calculate the area "under the curve", find the minimum and maximum of a function.
In addition to its graphing capabilities, a graphing calculator can be used as a scientific calculator. Sometimes it can also do statistical and financial calculations, matrices, list manipulations, operations on complex numbers, text editing,, creating programs etc.
Aug 13, 2010 | Casio FX-300MS Calculator
Wana reset lp 2844
to reset your printer, turn off the printer, then remove the cables and then press and hold the power button for 10 seconds. Reinsert the cables and turn on your printer...
Jul 01, 2010 | Zebra LP 2844 Thermal Printer
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to ti-cares@ti.com.
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
Cannot connect ti 89 to computer. I have installed the correct software from the ti 89 website for my computer and my calculator when I satart ti 89 connect it tells me there is an error.
Check to make sure TI-Connect is looking on the right port, whether USB or serial. If you have a serial cable, you might consider using Ti's Graph-Link software to connect. I have had trouble getting it to work right with TI-Connect. You can find Graph-Link on TI's Education site under Downloads > Connectivity Software. I personally prefer the free program TiLP, which runs on Windows, Mac, and Linux and supports whatever cable you want. Hope this helps!
Sep 29, 2009 | Texas Instruments TI-89 Calculator
Car dont wana start after i changed the wire harnest
which wiring harness??? u might have to reset the theft system by taking it to a shop or dealer.
Sep 05, 2009 | 2004 Cadillac CTS
Graphing calculator help
The cord that comes with the TI-83 Plus is a unit-to-unit link cable. It allows you to share data from one TI-83 (or other compatible TI calculator) to another. If you have the optional TI-GRAPH LINK adapter cable and the appropriate software it can also be connected to a PC.
For more info, here is the link to the manual. Chapter 19 discusses it in great detail.
http://education.ti.com/downloads/guidebooks/graphing/83p/83m$book-eng.pdf
Hope this helps..and good luck!
Sep 28, 2007 | Texas Instruments TI-83 Plus Calculator
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
