Question about Sony FD Trinitron KV-28FQ75 28" TV
T.v wont go past channel 36
I have a t.v that i don't have a remote to and when i change the channel it only goes up to channel 36 and then back to channel 2. How can I get all of my cable channels?
    Genius:
  • Sony Master
  • 1,689 Answers
I have not worked on this particular model of Sony. What I will say is for the ones that I have worked on.
If you are on cable, the set should be in the CATV or cable mode.
Go in to the user menu and look for section of the menu for the channel setup. There should be a prompt for auto program.
In almost all of the TV models the original factory remote is required to make any set-up changes in the TV set. What I explained is for TV sets that allow changes to be made from the front panel button controls.
Jerry G.
Posted on Apr 20, 2008
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
My remote won't let me channel down past a certain channel, I can type the numbers in and it will go but if I try to arrow down channels it goes about 5 channels and then starts back over where it started,...
mp_383
What channels are you able to receive? When you press the Select button on DISH remote, which light on the top of the remote lights up? The Sat button should light up when you are in satellite mode. If any other button lights up, press and release the Sat button and then try changing channels. If this doesn't work, we may need to troubleshoot with you. Please call us on 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Mar 08, 2011 | DISH Network 135899 Remote Control
Cannot change channel, volume, or select menu. will not accept input from remote anymore. you press menu, on the tv, nothing then you press volume or channel and menu pops up but as soon as any key is...
If the buttons do something, but not what they are supposed to do.....By chance are you using a universal remote (replacement for your original)? If so, the codes for the remote need to be re-set for use with your TV. Hope this helps.
Apr 09, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Hi, There is a black box in the middle of the screen, it goes away when you change the channel but comes back in 5 secounds
Try to toggle the close caption button on your remote control. I think there are three positions to set from if I'm not mistaken, may be from there you can solve your problem. Good Luck
Mar 07, 2010 | JVC AV-36D303 36" TV
My toshiba tv only goes up to channel 12, when it reaches channel 12 it starts back at channel 1.
You will need to re-scan the channels, i don 't know where it is on the menu of this set. If you are on cable, you need to make sure your tv is set to cable tuning, or you cannot get channels past channel 13. Same is true for antenna if you are on antenna make sure you are set for this.
Nov 20, 2009 | Toshiba 36A40 36" TV
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
Menu is on screen and tv wont do anything
try a hard reset first - unplug tv from power source and all cables for about 1 hour, reconnect everything and see..
Oct 26, 2008 | Toshiba 36A43 36" TV
Stuck on channel 2, "No Signal" and snow
Two things may be at play here. The tv might be only programmed for reception on channel 2 and will need to be re programmed to receive other channels.
Also try some basic troubleshooting on the remotes. Start with the remote that came with the tv. Replace the batteries try the "MENU" button. If you can get into the menu try to "autoprogram" the TV
May 01, 2008 | Sony KV-36FS100 36" TV
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
Sony FD Trinitron KV-28FQ75 28" TV Logo
119 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
