Question about Sony Ericsson K850i Mobile Phone
My K850i won;t turn on and I need to access some of the data help on the memory of the phone - is there any way I can do this?
Data recovery software corrupted memory
What's your problem? Nokia mobile phone is corrupted and you do need data recovery software to take corrupted mobile phone messages, contacts, videos, pictures and more? No panic! As long as you do have used a phone memory card to hold all these needed phone files, you often are able to recover lost cell phone data back from this phone storage card with the help of memory card photo recovery software related.
Merely connect this Nokia phone memory card to your PC and see whether this card could be smoothly accessed there. If so, merely go save phone memory card data backups well immediately.
But, if it could not be accessed due to some memory card errors, go search for a data recovery program online to take chance.
Jan 24, 2014 | Nokia N72 Cellular Phone
My k850i will not read any memory card yet it was doing so sometime ago.It says the memory stick is not inserted even when i try another memory card.help
Try to put the memory card and then restart the phone, usually this solves the problem.
But if the problem prevails your Ms contacts needs a cleaning, this will be done in servicing your phone through some service center, because it is not recommended to disassemble the phone yourself.
I hope you have a clear picture now,
Regards, WAQAR.
Nov 24, 2009 | Sony Ericsson K850i Mobile Phone
Operation failed
This is normally a sign that the firmware is corrupt - back up the data in the phone to the memory stick, and then run the SE update service program on a PC and reinstall the phone software (if it says "you already have the latest firmware", then select "reinstall anyway")
The update service application is here:
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/k850i?lc=en&cc=hk
Sep 14, 2009 | Sony Ericsson K800i Cellular Phone
Blank Screen
it happenes when the mobile Memory card have any unwanted or bad sector in it ... try checking your mobile without the memory card ... turn it off take out the memory card and then turn it On ...
Jun 23, 2009 | Sony Ericsson K850i Mobile Phone
Accidently deleted photos from my sony erricson k850i
Remove the Memory card and DO NOT WRITE ANY DATA TO IT.
Insert into a memory card reader.
Download a utility such as paragon drive utilities or my personal favourite (Restorer 2000.)
You will need to mount the drive using the program.
The Application will scap the drive for deleted data.
Select the deleted file(s) and restore to a folder of your choice.
NB. This will only work if you have not written to the card since you deleted the photos.
Good Luck
Feb 05, 2009 | Sony Ericsson K850i Mobile Phone
Sony ericsson k850i
REMOVE MMC BACK UP OF ALL UR DATA FROM PHONE MEMORY INSTALL SONY ERICSION PC SUITE IN UR PC AND
DOWNLOAD UPDATES FOR SONY ERICCSION MOBILE FROM SONY ERICCSION .COM INSTALL IT AND UPDATE UR MOBILE ONLINE.IT
WILL FORMATE UR MOBILE AND RESET UR CODE TO 12345 AND ALSO RESET ALL SETTINGS
i guarantee my solution is always right
plz dont forgetme to rate on fixya (blue line)
Sep 27, 2008 | Sony Ericsson K850i Mobile Phone
Making a wireless data connection
the bestway is to try geeksquad.com or google the issue
Sep 19, 2008 | Sony Ericsson W850i Cellular Phone
My Sony Ericsson K850i
This problem hapens to alot of S.E phones. the problem is with the mmc, when you access the music, sometimes the phone goes off. when it hapens, take out the mmc for a few mins then put it back in. the best thing to do though is to backup all your data on the mmc into the pc, then format the mmc. formating the mmc will lose all your data so it is important to backup your data. after formating, you can put back your music on the mmc. there is no parmanent solution to this problem
May 17, 2008 | Cell Phones
Sony Ericsson D750i SIM card transfer
From the main menu, Choose contacts
Select options and Press Advanced
Choose "Copy to SIM".
Select one of the options that pop up.
All the existing SIM card data is replaced when copying the contacts from the Phone to the SIM card.
Pictures and text message can't be saved to sim-card.
You need to transfer these with memory card or to computer and from computer to other phone.
Succes
Apr 04, 2008 | Nokia 6288 Cellular Phone
K850i memory access
You need to have the firmware on the phone reflash so you can do this on www.topsony.com this is a pay site also you can take it to a mobile service shop and ahve it reflash there.
Mar 31, 2008 | Sony Ericsson W850i Cellular Phone
Sony Ericsson K850i  Mobile Phone Logo
240 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
