Question about Microsoft Office Standard 2007 Full Version (License Only) Volume License for PC (1 Computers)
How to add hours:minut subtract from time time time diff. 01:00 02:00 1:00 16:00 18:00 2:00 ----------------- total hours
  • 51 Answers
Go to Microsoft excel click format in the tool bar then click cells then select time in the category scroll box
Posted on Jul 29, 2009
How do I input Degrees-Minutes-Seconds to convert to Degrees? Vice-Versa.
On any calculator, let's convert degrees-minutes-second to degrees and then we will do the reverse.
Let's start with the number of seconds in a minute - 60, so we must take the seconds and divide by 60 to get the number of minutes. Next, add the number of minutes. The number of minutes in a degree is 60, so we take this total and divide by 60. Now we add the number of degrees to get out final answer.
Example: 35 degrees 50 minutes 32 seconds
(32/60 + 50)/60 + 35 = 35.842222 degrees
Just out of interest, let's start with 35.842222 degrees and convert it to degrees-minutes-seconds. We know it is 35 degrees, the whole number. Now we have to determine the minutes and seconds. Start by subtracting 35 to get the decimal 0.842222. Now multiply by 60 to get the number of minutes. I get 50.5332. Subtract 50 from this and multiply again by 60. I get 31.9992, which rounds to 32 seconds.
Good luck.
Paul
Jul 06, 2015 | Texas Instruments TI-36 X Solar Calculator
My watch is 3 hours and 5 minutes off its a shp8948
1. Since all of the settings seem to go through the start/stop button, hold it down for three seconds to put it in "set the watch mode" (when the seconds at the bottom start blinking).
2. Do a quick press of the start/stop button to move from seconds to minutes to hours to years to months to days. The mode button subtracts & the reset button adds.
3. Setting alarms & so on require putting it alarm mode via the mode button. Use the reset button to move to the selected alarm (1-5).
4. Hold the start/stop button for three seconds to "set the alarm mode."
5. Quickly press the start/stop button to between things to set (kind of alarm, hours, minutes).
6. Again, the mode button subtracts & the reset button adds.
7. A three-second press of the start/stop button exits the setup mode.
Feb 27, 2015 | Watches
2.45.35 hours - 0.23. 12 hours = ?. a short quick method please
Seconds: Subtract 12 from 35 to get 23.
Minutes: Subtract 23 from 45 to get 22
Hours: Subtract 0 from 2 to get 2.
Put the three together to get 2.22.23
This one was easy because there was no need for carry. If you do have to carry, just make sure you carry 60. Otherwise, it's exactly the same as when you learned subtraction in second grade.
Some calculators have conversions between decimal degrees/hours and degrees/hours:minutes:seconds. If you have such a calculator, you can convert both numbers to decimal, subtract, and convert back. Since you didn't specify what calculator you have, I can't tell whether this is an option for you.
Jun 18, 2011 | Office Equipment & Supplies
I have a VPT24-1PZ 24 hour programmable timer.My question relates to after you progam the astronomic clock there is an off set option to add or subtract time from the sunup/sundown time.By pushing the up...
The timer lets you adjust the preset astronomic time for your area.
This is because actual local times vary.
If the preset time for dusk is 8:00pm and you add 12 minutes, then the timer will turn off-or-on at 8:12.
And then you can change the preset time for dawn by adding or subtracting.
If this is not what exactly you are asking, then set your timer and see what happens, and then add a comment with your findings.
Open following link to download on-line manual
http://waterheatertimer.org/Leviton-timers.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Leviton Hardware & Accessories
I do not have the manual. If I want to add or subtract do I put the total amount in and than hit the plus or minus key ? i.e., $128,000 -10000. do I hit the minus before the amount or after? -1500....
You can download the manual from
http://downloads.canon.com/cpr/software/calculator/P170-DH-(USA-HWB).pdf
128000 - 10000 then press = or chain the calculation by pressing + or - and the number you want to add or subtract.
Sep 30, 2010 | Canon P170-DH Calculator
How to add figures and then subtract from a larger number
use the + key after each number to add the total will appear on screen. When all numbers have been added, enter number to subtract and then press - key. The subtracted number will appear in read on the paper (if two color). and then press the star key to get total.
Jul 08, 2010 | Canon P23-DHV Calculator
What does MC,MR,M-,M+ on the calculator mean and do?
MR is Memory Recall
MC is Memory Clear
M+ is Memory add
M- is Memory subtract
These are used to add and subtract the answers to multi-step equations so you can do the small steps with the calculator, then store, change or recall the total as needed. You might add a long string of numbers in groups this way. Or you can do all operations in one parenthesis, then just store the total of each.
A good problem to illustrate this would be : (123 x 3) + (55 - 24) + (10^2) - (7 x 8) = ???
Using MR, M+ and M-, you can do each one as a group, and only store the answers. 123 x 3 = 369 so M+ to put 369 in memory. Clear it from the calculator. 55 - 24 = 31, so M+ to put this in memory and add to the 369 already there. Clear it from the calculator. 10^2 = 100, so M+ this to memory also to add it. Clear it from the calculator. 7 x 8 = 56 so M- this to SUBTRACT it from memory. Clear it from the calculator if desired. Now, when you then hit MR, you will get the total of all of these small equations in parenthesis -- 444.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 18, 2009 | Office Equipment & Supplies
Electricity bill coding in java
First think how you would solve this problem yourself on a piece of paper. Then try programming it using the things you learned (if they've given you this assignment without teaching you to multiply, subtract and use if's, drop the course).
Well here is an idea.
Take the total kilowattage and send it to a function. What the function will do is subtract 14KW from the total Kilowattage and add the amount for the first 14KW then subtract 85KW from the total KW and add the amount for the 85KW. But once you subtract the number of KW from the total make sure to check if the total KW isn't negative, if so just break out of the function and return the total due.
Or if you have formula for how much the rate grows over how many miles.
For example lets say the rate grows by $1 every time the KW doubles you could have something like
int rate = 1; //Begining rate
int KW = 14; //First flat rate
int amount; //total amount they have to pay
while(totalKW > 0)
totalKW -= KW; //subtract the first rate
if(totalKW <= 0) //check if too much subtracted
break; //if so break
amount += rate; //add the rate to the total
rate += 1; // Add $1 to the rate every time
KW *= 2; // KW is doubled
Jan 05, 2009 | Computers & Internet
Need instructions for setting a Sharp watch model # 2092
All the settings seem to go through the start/stop button. If you hold it down for 3 (not 2, not 4, but 3) seconds, it toggles in and out of "set the watch mode". You can tell you are in it because the seconds at the bottom go all blinky. Use (quick press) start/stop to move from seconds, to minutes, to hours, to year, to month, to day. Mode subtracts, reset adds. To set alarms, etc, first put the watch into Alarm Mode (Mode button, again).
Hold the start/stop button for 3 seconds to toggle into "set the alarm mode".
Quick press of start/stop moves between things to set (kind of alarm, hours, minutes).
3 second hold of start/stop takes you out of setting mode.
Jan 05, 2009 | Sharp Stainless Steel Code Ii Analog...
Clock
i just want out and played with buttons
Mar 09, 2008 | Car Audio & Video
Microsoft Office Standard 2007 Full Version (License Only) Volume License for PC (1 Computers) Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
