Question about Powercom Smart King UPS System
King Pro 2200 UPS - too low voltage in backup
Hi, I have an old King Pro 2200 UPS.
New batteries bring it to life with a problem:
-in back-up mode (no AC power) the output is only 170 to 180 V (instead of 230-240V).
Everything else is working.
Fan was out of order so it has been replaced also.
I suspect some components may have failed due to fan problem.
Do you have any idea what to test first?
Thanks,
Eric
Phone_Fundi
  • 91 Answers
SOURCE: problem with backup
check the fuse on the ups
Posted on Jul 25, 2008
  • 14 Answers
SOURCE: Powercom BNT 1500AP quit working after power outage
From your description it appears one or more batteries are bad..The circuit breaker on the Power Strip..which more then likely is a 15 Amp..tripped due to over current conditions..check the batteries and reset the circuit breaker..That should take care of it
Posted on Dec 31, 2008
mikeslab
  • 87 Answers
SOURCE: UPS shuts down when the mains is off.
Hi
After 3 years, i would by a new UPS...
The battery will have to be changed if you want to keep the old one.
What i've seen mostly here in south africa. When the battery life has ended they customer opens the ups and takes out the battery and then connects a car battery to the terminals. The then close the ups and let the car battery stand outside the ups.
Hope this info helps...
Posted on Apr 26, 2009
SOURCE: ups after 1 hr automatic disconnected and on only battery mode.
MY IND601A powercom UPS GETS OFF DIRECTLY
WHEN THE POWER GOES OFF?
Posted on Dec 26, 2009
Geekman
  • 32281 Answers
SOURCE: ups starts beeping
Is there any indicator lights ON showing the fault condition?
This could indicate that the battery has a low charge. Even if you switch off the mains supply and it switches over to the battery, the UPS may shut down after a short time as the battery power (charge) runs out.
If the battery is more than 3 years old then it may be due for replacement.
Posted on May 10, 2010
How do I fix my ups back-up with low voltage output, 175 volts only instead of 220 volts?
I would suggest that the battery is exhausted and needed to be replaced.
Jul 16, 2016 | Computers & Internet
27.5 volt charging voltage
No, that right. The batteries are wires in series so the voltage is 24v and they need a little high input than that to charge correctly.
Jul 25, 2012 | APC Back-UPS Pro 1400 UPS System
APC passes its self test but no backup
More than likely it is the battery. These units simply test the voltage during the self test, and, although not typical, the battery voltage could be good without a load, but fail with a load. 3 years is generally the life span of SLA batteries. Replacement batteries are fairly inexpensive and can be found at: http://batteryinternational.com/ups-batteries-apc-batteries.html
May 25, 2010 | APC Back-UPS CS 500VA UPS System
How should i connect four batteries in two batteries microtek ups
You should connect them parallel too to the other two parallel batteries.
While connecting, make sure you are connecting all blocks in parallel wirth the correct polarities. Also once all the batteries are connected measure the battery voltage at the UPS terminal and make sure it is around 12V
May 18, 2010 | Powercom King Pro 3000VA...
After a power outage my apc has this clicking sound. every 4 seconds or so it sounds like it clicks and then a slightly different click 4 seconds later. However, when everything is powered up it doesn't...
I found this on the APC website;
Question: What would cause a Back-UPS Pro, a Back-UPS Pro USB, a Back-UPS RS, a Back-UPS CS, a Back-UPS LS, or A Back-UPS XS to beep once every 5 seconds with no output power?
Answer: One beep every 5 seconds is an indication that the UPS has entered what is called "Low Voltage Sleepmode".
The Back-UPS product has transferred to battery power due to a low voltage condition at the wall. The Back-UPS has remained Onbattery until its runtime was totally exhausted, however, there was still enough voltage present at the wall to trickle charge the battery.
This is considered to be a normal operating state. When the voltage returns to normal the Back-UPS will wake up and restore power to the battery outlets.
Nov 02, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Computer goes off peroidically. Computer is plug into the APC Back-UPS Pro
Ensure proper input voltage coming in the location.
Ensure the working condition of the UPS Button switch.
If this APC UPS is 2 to 3 years old, better replace the Battery 7 Volts - 1 Number and check the problem.
If the problem persists, Please contact local authorized UPS Dealer Engineer to settle this issue.
Jul 16, 2009 | APC Back-UPSĀ® CS 500 UPS System
Hi
Apr 26, 2009 | Powercom BNT-600AP (bnt600ap) UPS System
Battery voltage not known for DELTEC PRR 2200
For deltec PRR2200i you got 4 pcs of 12 volts batteries and it was just connected in series
Jan 19, 2009 | Compaq UPS T2200 XR UPS System
Battery life
Generally, the battery life of a UPS may vary a lot, but is usualy between 2 and 4 years. It will be influenced by:
  • Quality of electricity in your area. The most outages, over-voltage, under-voltage, etc. there is, the shorter the battery will last.
  • Quality of the UPS. High quality UPS have additional features to protect the battery like AVR (Automatic Voltage Regulation) that will kick in mild under/over-voltage to avoid using the battery. Low quality/Entry-level UPS don't have this feature and will just switch to battery.
  • Quality of the battery. Some battery will last longer than others caused by the way they are made.
  • UPS load. The more the UPS is loaded, greater will be the load on the battery during an outage, reducing its life expectancy. The UPS should not have a load higher than 70%.
  • Storage time of the battery before being installed. A battery performance starts to decay from the time it is manufactured. So, longer the battery stays on a shelf in the factory or at the distributor, shorter its usable life will be.
If you are in an area with a lot of electricity problems, I suggest you simply replace the UPS for a high quality one and maybe over-size it a little to lighten the load on the battery. As an example, you may look for an APC Back-UPS RS (this is the one I am using), but there are other great UPS on the market.
On the other hand, if the electricity in your area is quite clean with very few problems, you may try replacing the battery. However, this is not a garanty since the problem may also come from the charging components in the UPS.
Hope this helps.
Apr 27, 2008 | Newpoint (200877) UPS System
Powercom Smart King UPS System Logo
50 people viewed this question
Top Powercom Computers & Internet Experts
David Payne
David Payne
Are you a Powercom Computer and Internet Expert? Answer questions, earn points and help others
