Question about HP Pavilion a1120n (PX759AA) PC Desktop
My computer cant turn on and its making noises
Just today my computer is failing to start, and its making noises when i try to switch it on. the monitor is not working
  • 746 Answers
Dear! If the CPU creates a beep its means that your CPU have a RAM problem then moniter does not give display. So change your Ram's slot and put RAM in other slot that is availabel and try again to start the PC. It is very possible to solve your problem and if problem will remain same you should change your RAM. Your problem 100% solve.
Thank You
Posted on Jul 29, 2009
  • 453 Answers
Try to unplug the cables from the CPU to the monitor.Unplug power cable. Press the power cable for 30 seconds. Do the same to your CPU as well.
Try to replug the cables back and kindly comment with the results. Check for any optical disks in the Optical drive and remove all the USB devices attached to the system.
Kindly comment whether you see any thing on the monitor or you see nothing at all?
If you see nothing I would suggest you to try your system with another monitor. If it works try with a different cable with the monitor and check if the monitor works. Try a different power cable. If none of these works then I would suggest you to call the monitor manufacturer for a replacement.
If the system does not work with another monitor then the issue is with either the Main board or the Graphics card. If the graphics card is external card then you can reseat it which is located in the PCI slot else the issue is with the main board and again the manufacturer needs to contacted.
    President:
  • 828 Answers
Did you your CPU Fan inside, that's the one who make some noises inside.
If your computer is failing to start then check CPU inside, all the peripherals double check on it. From VGA Card, Memory and other devices, maybe its not properly connected inside. Good luck!
Why is my computer shutting down suddenly
A computer that turns off without warning is often a heat related issue. Many computers today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets too hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing, this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer, you will need to either open the computer and make sure the fan are working and if your BIOS monitors the RPM of the fans, enter BIOS and make sure the BIOS does not report any errors.
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Sep 14, 2012 | Compaq Evo D500 PC Desktop
Imed 1402 wont boot up
Your computer is not completely booting (it's failing the POST).
You need to identify the problem by disconnecting everything but the CPU, video, and memory. See if you get something displayed on the screen. If not, there is a good chance the problem is in the video card. Just to be sure, if you have 2 sticks of memory, take one out and try a boot. Then swap sticks.
The monitor is blinking yellow because it's not getting a video signal.
Feb 20, 2012 | Packard Bell Computers & Internet
I have a Dell 193fp monitor. It's 5 years old and is used infrequently. Today the Power button started to flash amber repepatedly while making a slight clicking noise. After turning it on and off,...
This sounds like the power capacitors are failing, which is not uncommon for a monitor of this age. You can take it to a TV repairman and get the offending capacitors replaced, however, the cost of replacement may outweigh the cost of a second hand monitor
Jan 22, 2011 | Dell E193FP 19" LCD Monitor
I went on vacation and turned off my computer (the
mcdevito75 here, Your Monitor could be bad, (blown out) a monitor is just like a lite bulb. start your computer verify fan is on, verify monitor is on with on off switch on monitor, press shift key on keyboard maybe your computer is on stand by or hybirnation, also click the mouse at the screen left click and right click to bring picture to screen, if picture on monitor ok, if not press AUTO on the monitor, this brings back factory settings to your monitor. If all this fails, bring your monitor to a Radio Shack, Staples etc. for testing.
Jul 21, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
No power in the Monitor
Sounds like a fairly drastic fault, possibly in the power supply section. Probably not worth fixing with the cost of new LCD screens, but maybe worth asking at a local repair place.
Apr 06, 2010 | AOC 7F 17" CRT Monitor
Acer lcd monitor ''no signal''
It is screen resolution problem.
when you power up the computer press F8 key thene nter in enable vga mode then go to diaply property and set screnn resolution to 1024*768 thenh apply and ok.
Jul 12, 2009 | Acer AL1916W 19" LCD Monitor
Sceptre LCD monitor blank screen, blinking power light
Something has failed or is failing in the monitor. It may be serviceable, but may not be cost effective to do so unless something has just come loose. I'm assuming you have no problems with the new monitor. Your time line is a little confusing.
Dec 13, 2008 | Sceptre Dragon Eye D219A (White) 21 in.CRT...
Acer AL1917 Monitor does not start up immediately.
You'll need to have your power board -inverter redone.
The capacitors are starting to fail and that eventually will stop it all together.
I repair many monitors through ebay with these types of problems.
If you take it apart and send me a picture, I can usually see the problem areas.
ebays
bammbammfran
Nov 05, 2008 | Acer AL1917W LCD Monitor
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion a1120n (PX759AA) PC Desktop Logo
67 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
