Question about Gaggia Classic Espresso Machine
We have no lights, none of switches do anything, fuse in plug is ok
  • 1,089 Answers
Hi
There is a thermal fuse on top of the boiler that has probably blown. It is a 184c thermal fuse. You can get them from some of the internet sites like ChrisCoffee.com, Wholelattelove.com, or 1st-line.com.
Posted on Jul 29, 2009
I have an 03 GMC 3500 dually that the driver's side fender running lights won't light up. The passenger side work fine. Also my reverse light doesn't light up either. Could that be the problem?
check battery voltage both sides of stop light switch if if none check fuse , if one side only replace switch, if ok check voltage at light bulb holder if ok check bulb or earth system
May 02, 2017 | GMC Sierra 3500 Cars & Trucks
I have a mini cooper 2003 and none of my brake lights work.i thought it might be brake light switch but when i put a wire across the connector lights still wont come on. fuse ok
Have you checked for power with a multimeter at the switch ? I'm going to say the obvious....you didn't say if you checked the bulbs ?
All being well there...find the grounding spur and check that is sound and that all wiring plugs are secure and not fouled up.
Dec 03, 2014 | 2002 Mini Cooper
My lights quit working
Hi Brandon
Use a 12v multimeter or a test light to trace fault from headlamp backwards.
Probably check across each fuse first to see if you've blown one.
OR
Check one side of the Headlamp switch for voltage first.
No volts there means no power to headlamp. then trace back.
Like all electrical troubleshooting, it's a process of elimination.
Take a piece of paper and draw a headlamp circuit.
Battery, Fuse, Switch, various connectors, and Headlight.
Use that to guide your tracing.
Good Luck
Trevor
Jul 22, 2014 | Honda 2005 TRX 450R
Testing a headlight relay t-100 Toyota 95
If the ALT FUSEand TAIL FUSE are good, the taillight relay may have failed. If the STOP FUSE is good, the stoplight switch may have failed.
Mar 31, 2014 | 1995 Toyota T100 Xtracab
Turn signals don't work in my 2000 Nissan Xterra. Fuses are OK
Could be a bad multifunction switch or even the flasher relay
Apr 19, 2013 | 1999 Volvo S80
Brake lights don't work ,fuse ok , bulb ob , brake switch ok, third brake light ok, turn signal ok, running lights ok
run a continuety test between all terminals on the brake light circuit to see if you have continuety if a break in the circuit is present then investigate is this due to a switch or a none connection..hope this helps kev
Nov 27, 2010 | 2002 Hyundai Santa Fe
None of the interior lights work.
same thing happend to me took it to dealership found out it was my relay switch or switches
Jan 05, 2010 | 1998 Cadillac DeVille
Parking light nightmare1987 dodge dakota
Your problem could be Rust in rear lights causing bad earth or shorting in parking lights or rear lights as plug shorting so.....unplug rear lights from plug to rear lights inc No plate light, switch on if still blows unplug both parking lights ....then OK so problem in f/p/lights,,connect up Left hand side ,,,still ok then problem in R/H/Parking light ,,,but dont forget when finnished to put them all back, and numberplate light as well (they are the most troublesome light)
Have a goodday
Sep 24, 2009 | 1987 Dodge Dakota
The tail lights are still dead. Checked all the fuses (none id them as lights, or the like) and they are OK. Noticed last night that the center console inside are also out(not where the speedometer, etc...
interior lights are controlled by the fuse box in your car... your tail lights are controlled by both the fuse box inside the car and the one under the hood
Aug 20, 2009 | 2007 Nissan Quest 3.5 Minivan
Third brake light works, but brake lights L/R don't.
faulty turn signal switch would effect brake lights if its faulty.because brake lights and turn signal feeding off same circuit.
Jul 10, 2009 | 2001 Volkswagen Beetle
Gaggia Classic Espresso Machine Logo
328 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
