Hello, friend! I happened to see you with this problem, I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.They have professional unlock tools.
They are free to consult, I hope that the programmers I recommend can help you.
SOURCE: Broken flip
Hello, Verizon has to repair your phone for you!!! I had the same exact problem and they said it was a defective part and that they would fix it... Just go into the store and tel them they have to because it is a known default. I just had to get mad. After i did that i got alot more help. Good luck!!!
SOURCE: USB 2.0 device
All you have to do is Windows update! Sorry, everybody has to update their version of Windows. If you want windows to let you know when there are important updates I can show you how to set this up. Open control panel, open the icon System. Click Automatic Updates tab. You will see you have choices. Pick one. Click Apply & than OK. After your computer is all updated try your iphone again. I'm sure it will be fine. Good day!
Please vote......
SOURCE: Pairing tungsten t3 with newer cell phones
I use Bluetooth to synch to my Sanyo cell phone, so I would think you could do the same. I maintain my Contacts in Outlook and synch with my Palm. I then synch my Palm to my phone.
1. Make certain that your Contacts (in Outlook, Palm Desktop, or whatever you use as your source to feed data to your Palm) contains ALL the phone numbers you want in your phone.
2. If, like me, you have a lot of contacts and a limited number (500 in my case) of contacts that can be stored on your phone, you will want to erase all contacts on your phone first.
3. On your Palm, go to Preferences
4. Select Bluetooth -- Bluetooth should be ON, Discoverable (Yes) and Connectable (Yes)
5. Turn on your Bluetooth-enabled cell phone -- I believe the range is 20-30 feet but I have not tested that. When I synch, I have them both on my desk because I want to see that it is working.
6. Select Trusted Devices. Hopefully, your Palm will detect the cell phone. When it does, add your cell phone as a trusted device.
7. Select Contacts on your Palm and use the pull-down menu to select Send Category.
8. Select Bluetooth
9. Select your phone
10. Your phone will probably indicate that it is receiving data. You should soon have all phone numbers stored on your phone without using a direct-connect cable.
SOURCE: Why can't I recieve text messages from other cell phones?
I had this problem once with another cell and I found out that some of the text messages from other phones, like the LG and PDA phones send with kilobytes that are needed to be "downloaded" through a multi-media package or internet access. If you are able to send texts and they receive them, check with your carrier.
Also, try shutting the phone off and restarting.
Let me know if this helps.
