Question about Samsung 793S 17" CRT Monitor
Yellowish colour of the monitor
All of a sudden my pc monitor colour changed to yellowish inbetween it comes to normal but same problem again yellowish
what should i do pls help?
  • 4 Answers
Check the datad cable of monitor, if ok.then soldring may be dry ot the CRT neck
Posted on Jul 29, 2009
Shows different color complete blue or red scrren at connection
shake vga cable at different places & observe.........if colours becomes normal or it comes & again it goes...then vga cable is deffective.......either you have to change full vga cable or you have to repair that cable itself................after shaking cable also if no improvement then......hit your monitor lightly on left side or righr side or on top & observe ...........if colours becomes normal or it comes & again it goes...then following is the situation...............after 4 or 5 yrs in some monitors on main board at some soldering joints crack develops....then due to loose contact colour problem comes (1 of the sympton) ...........when we hit that lightly then those loose contacts joins temporarly & again colour comes nomally for some time............so solution is ......monitor main board & crt circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no improvement then..following is the situation.....................on CRT circuit board ( circuit board that is fixed to tube) ''red green blue'' - video output IC ( some thing like LM2469TA ) will be there - it should be replaced - usually it will be fixed to heat sink ------- before changing IC all the components on CRT circuit board should be checked ( after switching off monitor ).........this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 11, 2011 | SAMTRON 55V 15" CRT Monitor
Monitor displaying purplish colour and sometimes blinks
Have you checked the cable that connects from PC to monitor ? If its VGA, it will be a 15 pin cable. please check both ends of the cable if any PIN is broker or bended. or remove it and tight it again. If that does not solve, the monitor will have some hardware issue.
Mar 03, 2010 | Computers & Internet
The color suddenly changed to where everything has a yellowish tint. And now the display is too wide to fit on the screen. How do I get it back to normal?
Right-click any free space on the desktop, choose properties, choose display, change the settings to 32-bit and which ever screen ratio you want.
Nov 20, 2009 | Proview PL926WBi 19" LCD Monitor
My monitor colour has changed to yellowish
The first thing to try is to make sure the video connections both at the monitor and the PC are secure. A number of color image problems are just a loose connection. Make sure you remove the connectors and then reseat them when you do this.
Jul 28, 2009 | Samtron 76df 17" CRT Monitor
The screen is appearing yellowish and the colour no longer normal like before.
check breakege of video cable and vidio section of monitor kit
Jul 16, 2009 | Dell SE198WFP LCD Monitor
The colour depth of my monitor is more yellowish.
is better check your vga cable which attached pc to monitor or change your monitor color on setting
bye
Jul 08, 2009 | Compaq CV 7500 17" CRT Monitor
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
My monitor displays yellowish color instead of original color
yes please take the power on self test means disconnect signal cable and monitor will give
display without cpu if display appears then monitor ok fault is in cpu if not then fault is in monitor move signal cable and look display changes or not if changes then cable faulty replace it
Nov 11, 2008 | SAMTRON 55V 15" CRT Monitor
Need solution for the yellow display of my monitor
You can see one ic in right of crt base,plz resolder it (90%sure)
Sep 14, 2007 | SAMTRON 55V 15" CRT Monitor
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Samsung 793S 17" CRT Monitor Logo
144 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
