Question about LG Washing Machines
Replaced the ball sensor and error message still
Replaced the ball sensor in an LG WD1433RD and error message still displayed on the machine
4 Suggested Answers
kevin000
  • 1847 Answers
SOURCE: LG washing machine WF-T1031TP erra
light flashing means that there not sufficient water coming through the inlet.
Posted on Aug 04, 2008
techbuster
  • 5081 Answers
SOURCE: I have a LG washer dryer wd1433rd that keeps
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble.
CHECK THE BELOW LINK:
http://www.fixya.com/support/r2127066-le_error_code_lg_washer
Posted on Mar 31, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have LG Washing Machine
The load balance sensor is likely failed - or the vibration dampers are broken. Check their mounts as well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
LG WFT1391TP Top Loader - Water continues to fill drum until overflowwing and wash cycle does not work. error message received. spin cycle works
The tube that goes to the level sensor has perished or fallen off, or the level sensor itself has failed.
Jun 14, 2015 | LG Washing Machines
LG Washer with bE error code
I find no info on a bE fault code. But you mentioned a "ball sensor." Do you have info i don't?
Jan 30, 2013 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a LG WM1814CW washer that has started giving me the UE error code. No matter what I do it does not solve the problem. I have even run the machine empty and the problem still comes up. It usually...
You may have a problem with the ball sensor. Look in the back of the washer. On the right side as you're looking at the rear, does the frame look slightly dented in?? If so, you will need to pound out the metal. The reason is that the ball sensor is located on the lower right side of the back panel and if it is pushed in enough, the spinning movement from the tub will knock the ball sensor causing the control board to display UE error code. Good luck
Jun 19, 2011 | LG WM1814CW Front Load Washer
Hi, hope you can help, I have a 4 kg LG Washer / Dyer (model WD - 1433RD). It is displaying "CL" on the readout. Have lost the manual so wondering if this is a simple fix or not?
CL means that the child lock feature is active and the control panel buttons will not respond. For the LG WD1433RD, press and hold the Rinse+ and Pre-Wash buttons together for about 3 seconds to toggle the lock off. For the LG WD14311RD, press and hold Option and Rinse for about 3 seconds. On both washers, there is a small icon between the two buttons needed to toggle the child lock feature on and off. (It's a small face above a padlock.)
The manual as a Djvu file for the LG WD14311RD is available here: http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=WD-14311RD&initialTab=warranty&targetPage=support-product-profile .
The manual for the WD1433RD is available as a PDF here: http://www.manualsonline.com/ex/thread/view/idThread/80183 .
I hope this helps.
Apr 06, 2011 | LG WD14311RD Front Load Washer / Dryer
LG inverter Direct Drive 7kg WD11020D - what is "ue"?
UE is the error the washer will display if it detects an unbalanced load. If your LG washer was a model that contained the Ball sensor, it could be a bad part.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800
Mar 06, 2011 | LG Washing Machines
My machine keps stopping and giving a 6E message
Hi
Thanks for using FixYa. Error 6E is a ball sensor error which is displayed due to loose Ball Sensor Connector and/or when the Ball Sensor goes bad/is out of order. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | LG Washing Machines
I have a LG washer dryer wd1433rd that keeps coming up with LE error....ive tried unplugging it...resetting it....is there anything else i can try?
Mar 31, 2010 | LG WM-2277HW Front Load Washer
Lg wm2010cw Washer Drum Banging and Vibrating
yes was the counter weights aka shock absorbers
Apr 16, 2009 | LG Washing Machines
I have LG Washing Machine Front Loader - WD1433RD. The display says LE and when I looked up the manual it is overoaded. However there is not much load in it. Any idea ?
Jan 13, 2009 | Washing Machines
Washing Machines Logo
216 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
